Brake squeaking
RE: Brake squeaking
Did you have the rotors turned before the new pads were put on? If not that could be why. Remember squeeling, or high frequncy brake noice isn't typically indicative of lack of stopping power or anything. I've been looking hard for the mimum rotor thickness. You know, befoe you have to buy new ones and use the old ones as clay pigeons on a skeet shooting range. If you can't grind the old ones cause of lack of proper tools or you think they might be a little thin or warped, I'd just get new rotors myself. HTH
RE: Brake squeaking
Take a flash light and look at your brake pads to make sure you still have some surface left.
If your pads are still good they make a greese you apply on the back side of the pads that reduces brake squealing.
