10-29-2011, 04:23 PM
Level up: 58%, 21 Points needed |
Coolant Leak, Help!
I went to start my car today (A4 B6 1.8T Quattro) and Low coolant alarm/flashing screen deal comes on, I step out take a look under the car, sure enough drips coming down off the car into a big pool of dried coolant. I pop the hood to see almost no coolant left in my reservoir, I try and pin point the problem and I find this..
Underneath..
Zoomed out to show where I am looking..
Zoomed in on coolant drip area..
Maneuvered camera around inside to get a good look at the drip area..
Seems to me that it is leaking from the area circled in blue, But I do not know what this is.. what could be leaking coolant behind the head there?
Doubt I can fix this today, hope it's nothing major but rather than drive it anywhere and risk any damage i'm just letting it sit for now till I can pinpoint the problem!
10-29-2011, 04:54 PM
Level up: 45%, 55 Points needed |
coolant flange
10-30-2011, 12:41 AM
Level up: 50%, 75 Points needed |
yeah thats the coolant flange and its a pain to change you got to remove all that staff in front of firewall so you can have room to work. if you know whats your doing it should not take you that long.
__________________
A4 B6 Quattro Black
A4 B6 CVT Silver
Next: Timing Belt done both cars.
10-31-2011, 12:31 PM
Level up: 99%, 3 Points needed |
__________________
11-03-2011, 04:27 AM
Level up: 96%, 2 Points needed |
Just did the job 3 days ago on my 1.8T Quattro... my coolant flange was on the rear next to the firewall. here is a DIY writeup that helped me out:
B6 A4: DIY Rear Coolant Flange
Things that helped out:
1. remove the airbox completely
2. use a small amount of gasket maker to hold the large o-ring in place
3. Be EXTREMLY careful with the 2 bolts that hold the coolant flange to the head. I stripped one of the bolts which then lead me to tap the hole and use a larger bolt
Tags
04, a4, audi, audicoolantleak, b6, car, coming, coolant, drip, fluid, leak, leaking, low, raditor, rear  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
