Engine Check Light: No Warm Up above 1K RPM/Hesitation/Oil in spark plug #3
New guy here.
Auto Scan Results:
VCDS Version: Release 11.11.1
Friday,06,January,2012,12:26:43:42594
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 232090km/144214miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016581
Shop #: WSC 63351 000 00000
VCID: 74ECD29D14A00F4
4 Faults Found:
16501 - Engine Coolant Temp. Sensor (G62)
P0117 - 001 - Signal too Low - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
16687 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
17658 - Fuel Level too Low
P1250 - 008 -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 FF
Component: V30 01J 1.8l5VT USA 3011
Coding: 01001
Shop #: WSC 63351
VCID: 75EAEF994FDA16C
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
Coding: 04279
Shop #: WSC 06435
VCID: 2C5C0AFDDC10174
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2952F3E9D3E202C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
VCID: 346C129D04204F4
2 Faults Found:
00984 - Left Tail Light (M4)
57-00 - Electric Circuit Failure
01493 - Bulb for Blinkers; Front Left (M5)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 06435 000 00000
VCID: 377625914556A4C
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
VCID: 3E7830B53A6C954
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 02200
Shop #: WSC 65535
VCID: 32601485FE34414
WAUJC68E23A340535 AUZ6Z0C0064257
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72E0D4853EB4014
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0003
6 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 01201
Shop #: WSC 26097
VCID: 2A500CE5D6E4094
End ---------------------------------------------------------------------
Replaced Engine Coolant Temp. Sensor(G62).
Oil and filter Changed.
Replaced spark plugs(needed) and found a puddle of oil in spark plug #3(misfiring #3 alright). Other plugs were ok.
Question:
Is this likely to be #3 spark plug seal, valve cover seal? Any chance this could be cylinder rings? 2003 A4 1.8T has 144k. Timing belt/water pump have been changed.
After replacements above A4 runs smoother yet not warming up as it used to be even after engine coolant temp sensor change. I read a post where someone was having engine hesitation and it ended up being the bleeder valve=PVC valve.
https://www.audiforums.com/forum/aud...4-1-8t-172912/
Feedback is appreciated. Thank you.
Auto Scan Results:
69 75 76 77
Coding: 0016581
4 Faults Found:
16687 - Cylinder 3
P1250 - 008 -
Coding: 01001
Shop #: WSC 63351
Coding: 04279
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
No Faults Found
Coding: 00003
Shop #: WSC 63351
2 Faults Found:
Coding: 0010607
Coding: 00041
Shop #: WSC 63351
Coding: 02200
Shop #: WSC 65535
Coding: 11788
Shop #: WSC 63351
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 01201
Shop #: WSC 26097
Question:
Update:
Normal Engine warm up is working again since this morning so I suspect the Engine Coolant Temp Sensor fixed that.
Still wonder if anyone here has ever have oil in #3 cylinder spark plug on an A4 1.8T.
Thanks.
Thanks.
i had oil on all 4 spark plugs. Thats the valve cover gasket problem (also had that random/multiple misfire code). When u will do a gasket do not forget to change your PCV valve
the heat should start to work when u bleed the system and clear the codes.
Bleed witch system the heat system i had herd that sometimes u can grt fluid in the heater matrix, also ive never changed the temp sonsor coild it be that i already ordered the gasket to fix the leak
