engine light flashing, rough idle '02 A4 - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 07-18-2008, 07:27 PM
Default engine light flashing, rough idle '02 A4
02 A4, 1.8T, running great yesterday.
On the way to work this AM, engine started skipping, and check engine light started flashing.
Rough idle at traffic lights.
Just turned over 80,000 on ODO.
My initial thoughts are change the plugs, and maybe coilpacks have gone bad.
I have VAG-COM it said misfires on cylinders 1 &3.
Didn't hear the turbo at all.
I'll start with plugs, but does anyone recognize these symptoms as a computer component failure?
Wanted to ask the group for help before I chase my tail for days.
Thanks in advance for your time and interest.
Old 07-18-2008, 09:14 PM
audiprotein's Avatar
Default RE: engine light flashing, rough idle '02 A4
Coilpacks
Old 07-18-2008, 09:30 PM
definately! i had the same problem on my 02 and it was the coilpacks!!!!!
Old 07-18-2008, 09:55 PM
yep def. sounds like the coil packs. Had to get new ones from the dealership. 30 dollars a pop. from what i read that if you had the older ones they might be covered under warantee by the dealership because of a recall on them. But might want to check it out if you dont want to dish out 30 for one. mine was at 102k when mine went...
Old 07-19-2008, 11:51 AM
I keep two coil packs in my trunk I've blown through 5 in 4 years
Old 07-19-2008, 06:20 PM
Guys -
Went to replace coilpacks, found spark plugs covered in oil.
Oil had somehow pooled around the plugs, one wasn't even visible.
So I changed all plugs and coil packs.
Got a great big cloud on the first start after removing spark plugs, oil leaked into ignition chambers I guess.
Have any of you ever had an issue with oil collecting around plugs?
What causes it, how does it happen?
Old 07-19-2008, 10:51 PM
hardenthefckup's Avatar
tighten the spark plugs down really good
Old 07-20-2008, 04:18 AM
Default do not tighten plugs too much
uhhh, do NOT tighten the spark plugs really tight. basically you want to tighten them a little more than fully. if they are tightened too much you can cross thread them easily, then you are fucked.
Old 01-27-2009, 09:29 PM
yeah don't overtighten them cuz then you are screwed big time. Sometimes the oil in the plug chambers is caused by the valve cover gasket needing to be replaced. There is a good diy forum out there for this that I have seen.
Old 01-28-2009, 08:29 PM
Talking
Coil Pack!! since I have did the APR stage I, I have been going thought these coils every 7 months.
Reply
Thread Thread Starter Forum Replies Last Post
2000 a6 4.2l Rough Idle & MIL Light Flashing mcmopar Audi A6 5 05-27-2015 08:20 PM
Rough Idle & MIL Light Flashing audijoneseyy21 Audi A6 7 08-26-2012 08:20 PM
2003 a6 rough idle/check engine light flashing dunnracin Audi A6 2 05-03-2012 11:01 AM
PLEASE HELP ME! 99.5 Audi A4 rough idle flashing check engine light AWD_Addict B5 Models 13 05-18-2011 05:42 PM
Rough Idle and Check Engine Light Willfulone Audi A4 6 04-07-2006 03:11 AM
Tags
18t, 2008, a4, a6, audi, b6, change, check, engine, flashing, idle, light, oil, rogh, rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
