Ground cable & Battery cable
Old 06-18-2013, 11:07 AM
shuggy81's Avatar
Default Ground cable & Battery cable
Hi Guys,
I done something a little silly the other day. Trying to swap my amp over I removed the cables, however accidentally the Battery cable (Power) touched the Ground cable and there was a slight spark and it stuck to each other. At this point the car was not on, and these cables were removed from the amp.
I'm guessing by this the amp is fine, and the car seems fine too as the head unit comes on. However the amp itself does not power on. I believe I have blown a fuse somewhere however I can't seem to find where it could be.
Any suggestions ?
thanks
Old 06-18-2013, 04:50 PM
ECS Tuning's Avatar
Sponsor
Probably blew the fuse on the amp. Check that first.
Jason
Old 06-19-2013, 12:38 PM
pa4ul's Avatar
or you could have blown your inline fuse that runs between the battery and the amp via the power cable.
99AudiSport
09-06-2012 06:29 PM
Van Dutch
08-31-2010 09:31 AM
bleuachdu
08-29-2007 05:06 AM
rink2rink
06-07-2007 06:12 AM
rink2rink
06-06-2007 08:59 PM
Quick Reply: Ground cable & Battery cable
