Limp mode? PRNDS backlight on........what coudl be the problem
Old 08-14-2009, 12:49 PM
princeking's Avatar
Default Limp mode? PRNDS backlight on........what coudl be the problem
hows it going, i need some help. when start my car and its in park the dash shows that its in park but when i put the car in D or Tip the PRNDS all come on with back light. however when i shut the car off and select P its fine, N its fine and S its fine. i can drive all day in S and itll be fine but as soon as i switch to D PRNDS comes on and than it stay on even if i put it in S. its clears when i restart the car and drive in S.
is it in limp mode? maybe something unplugged.
any advise on how i can fix this problem. fault code is
18161 - Tiptronic Switch (F189): Implausible Signal
P1753 - 003 - Mechanical Failure
Old 08-14-2009, 09:31 PM
Dan1969's Avatar
I don't know if this helps in anyway: http://74.125.153.132/search?q=cache...&hl=en&ct=clnk
Old 08-15-2009, 05:04 PM
rustlerboi1052's Avatar
You are not alone. I have this EXACT same code right now. If I find out any information I will let you know.
Old 08-16-2009, 07:00 PM
princeking's Avatar
it helps i understand now what it could be, now i need to figure out where do start? the gear shifter the tranny or the engine..?
Staudi911
01-15-2015 03:20 PM
bottlecap
11-27-2009 05:40 PM
jzstuggie
09-07-2009 11:41 AM
drs305
12-10-2007 11:14 AM
djjay
04-20-2007 02:17 PM
Quick Reply: Limp mode? PRNDS backlight on........what coudl be the problem
