I have my door panels off but I can't get the window up because im missing the large torx. Is there any way to manually lift the window up without taking the foam and panel off??
can u grab the top of the window and pull it up. If not to get that foam cover off the door use a blow dryer or heatgun and that will help loosen the glue up and then peel from a corner.
