P2181 need help
Old 12-04-2016, 09:29 PM
Abelsaudi805's Avatar
Default P2181 need help
So i recently replaced my thermostat because my car would not heat up to operating temperature, until about 40 mins of driving and anytime that i would reach a stop the gauge would go back down, after changing the thermostat, the car ran perfectly fine and the check engine light didnt pop back up. Now after about two months my check engine light came on and it takes like 20 mins to reach operating temperature but the gauge stays at operating temp once it reaches it, i changed the 2 and 4 pin coolant temperature sensor. My check engine came on again after i changed both of them and it still read p2181, idk what else it cud be unless i installed a faulty thermostat that is stuck open but then it wudnt be reaching operating temp if that was the case?
Old 12-05-2016, 12:52 AM
hartsoe1's Avatar
should we assume it is an R8?
Old 12-05-2016, 01:56 AM
Audi a4 2003 1.8l Turbo
Old 12-07-2016, 06:09 PM
sheldon's Avatar
I would check the basics with the help of VAG-COM:
18613/P2181/008577 - Ross-Tech Wiki
It should point you in the right direction.
Also did you clear the codes after replacing the sensors?
Old 12-07-2016, 09:31 PM
Yes i cleared all the codes and made sure everything was wired correctly
Shell
04-15-2012 01:49 AM
Damaniac311
B7 Models
04-10-2012 10:54 AM
ricketts6
01-25-2012 08:06 PM
BraincellGenocide
B7 Models
01-20-2011 02:36 PM
Quick Reply: P2181 need help
