Stock o2 sensor(s) on 2002 A4 3.0?
Is the stock o2 sensor on my 2002 a4 3.0 a 4 or 5 wire sensor? Some sites say 4 some say 5, and they only make an o2 simulator for 4-wire o2 sensors, so gotta know before I order! Thanks so much, and btw how many sensors total are there on my car? Thanks!
-Daniel
-Daniel
You have 4 02 sensors total, 1 pre-cat sensor and 1 post-cat sensor on each side. I recently replaced a post-cat O2 sensor on my 02 A4 3.0, so I know the post-cat O2 sensors are 4 wire and I would bet that the pre-cat sensors are 4 wire as well.
How do we know which sensor is bad? Each of the four cost about $100 at AutoZone and if they all need to be replaced then so be it but any help would be appreciated.
Codes: P0118 engine coolant temp high input
P0393 cam position sensor B bank 2 high input
These are probably coming from a bad O2 sensor, right? Car has 105k miles, 2002 3.0
Just replaced camshaft positioning sensor. CEL came back on- comes on an off now. Need to replace o2 sensors probably...
Can you tell me what error code made you to replace O2 sensor and what error code fixed since you replace O2 sensor ?
Thanks
What error message getting Now?
Still P0393? which is cmashaft position sensor even you replaced camshaft position sensor.
Did you do yourself?
I'm planning to replace camshaft position sensor on driverside because of P0393 on my a4 3.0L
I could be wrong but the CEL likes to come on after I put new gas in the tank. I haven't had a code pulled since topping off antifreeze. I will try to get codes updated during oil change on Saturday.
Not proofread
I got used A4 recently, 2001 2.8L Manual and 2002 3.0L Auto.
Both got CEL soon after we got.
2.8L I don't remember but related secondary air and
3.0L got Code P0393, P0431 and P0421.
I did many research and checked for both.
I can tell both car had leak on vacuum hose.
All that related emmisions
Please check vacuum hose and connections, secondary air and Intake manifold flap valve actuator.
I can send drawings and Pic's if you give me email address.
Hi I'm also getting all the same codes you had got, did you fix all 3 codes to get your check engine light off? how hard was it to change the camshaft position sensor & O2 sensor? I'm thinking about doing it all myself.
crazyquik22023
05-20-2012 01:53 AM
