Transmission problem, Fault code "P1744"
After having problem with my transmissin which occasionally went from "D" mode to "1st" gear in Tipronic mode automatically which showed up on dashboard manual gears while on DRIVE MODE, i got my car scanned again today from different shop and a fault finally showed up with this info "18152 Tiptronic Recognition Switch (F189) Short to Ground P1744 Mechanical Function", AND the mechanic drove my car for a while and found out that in D (Drive) mode, the gears changes manually when shift up to N (Neutral), and down shift wen hitting the S (Sports) mode, STRANGE, So as a result the car drives manually (Triptronic) in D (Drive) mode while nothing happens in Tiptronic mode lol crazy.
Argelius
B8 Models
09-14-2017 11:41 AM
ssingh
02-09-2011 06:13 PM
