trouble bleeding coolant a4 2.4 v6
Edit: I stand corrected; I just found a reference to a 2.4 liter mill Audi used to produce in the 5-Valve per cylinder configuration. With that in mind, my guess is that you're not in North America; yes, no?
Under the assumption the 2.4 is a sibling of the 2.8, then ss for there being a bleed screw, no, not that I'm aware of. As for no heat, have you replaced the thermostat?
