Vibration when idle in gear, goes away on gas
Old 10-21-2013, 05:37 PM
kwa4's Avatar
Default Vibration when idle in gear, goes away on gas
I recently started having an issue with my A4 whereby the car runs/drives great, but when I come to a stop at a light, etc. it vibrates a ton. However, if I take it out of gear and into neutral (automatic tranny), it stops vibrating, but starts again when I pop it back in gear until I hit the gas. The vibrating (also mildly loud) doesn't go on until I get basically to a stop or maybe 1 mph, and goes away pretty much immediately when I hit the gas again. It has also begun to vibrate more when under load, such as when I hit a bit of a hill on the freeway and thus it has to put a little more power in to maintain speed.
Any ideas?
If it means anything, recently changed the oil, use the recommended high mileage synthetic, but it ran great, drove a few hundred miles road trip then this started happening, but worried it could be overfilled if that could cause it.
2002 1.8T w/131,000 miles
Old 11-20-2013, 09:11 PM
jtblue's Avatar
Sounds like it might be your engine mounts.
Old 11-21-2013, 04:09 PM
pa4ul's Avatar
i would lean towards your snub mount. ITs located between the oil drain and the front bumper. U should actually be able to stick your head under the car if your undertray is gone and see it. NOrmally after a while the foam becomes brittle and will cause that vibration.
kwa4
08-17-2015 11:31 AM
Mossyoakglock
09-13-2013 11:11 PM
AudiOso
02-17-2008 10:00 PM
nrichlen
09-11-2007 04:40 PM
goodsed
09-09-2005 06:42 PM
Quick Reply: Vibration when idle in gear, goes away on gas
