02-13-2011, 01:46 AM
Where do i fill my transmission with fluid??? Please help
HI 2002 A4 3.0 QUATTRO A/T here .. can anyone tell me or show me with pictures where it is the i can fill my transmission with at fluid..
thanks in advance
__________________
2002 Audi A4 3.0 quattro.......
02-13-2011, 09:24 AM
Level up: 63%, 56 Points needed |
First, what makes you think it is low on fluid?
In answer to your question, there is a recess in the bottom of your transmission pan with a large allen in the recess.
This is where you fill it by pumping trans.Fluid into the hole.
The car must be level, and up to operating temperature when you fill it.
You fill it until it runs out of the hole with the allen removed.
The proper procedure is to connect a VCDS, and monitor the transmission temperature and fill it at the specified temperature.
I would also strongly suggest you go to your dealer and get factory fluid, as mixing brands would probably not be a good idea.
If your car has close to 100K miles on it, it would be a good idea to change fluid & filter.
__________________
2001 A6 4.2 Quattro
1998 A4 2.8 Quattro 5sp.
VAG available-SW Missouri
02-13-2011, 10:06 AM
No i dont think its low ,,, i just wanted to know for future reference because im really confused and undecided on changing the fluid and filter because it has 131k on it and dont want to loose the friction between gears if i do .. do you think its safe for me to do it? please let me know thanks...
__________________
02-13-2011, 01:47 PM
Points: 13,191, Level: 74 |
Level up: 86%, 59 Points needed |
Quote:
If you're not familiar with it or experienced with a vag com, then no its not very safe for you to do it yourself.
__________________
99 Chevy Silverado Z71 6" rough country lift/W 35" tires, 4.10 gears, (4.56 soon) S&B CAI and a flowmaster super 44 exhaust.
"Never argue with a fool, they will lower you to their level and beat you with experience." My personal motto.
Tags
2002, 30, a4, a6, audi, b6, change, check, fill, fluid, location, quattro, refill, tranmission, transmission  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
