07 A4 Bluetooth Setup
I just bought a 2007 A4 2.0T s-line 6 speed and I'm wondering how to set up the Bluetooth. I read the entire owners manual and didn't see anything on setting it up. I tried messing around with it and turned my phone's bluetooth on but it still doesn't seem to work. I have a Droid. Anyone have any advice?
I have no problems getting my Droid to sync with my 07 A4 Avant. You have to make sure you phone is in bluetooth discovery or "visible" mode before you turn the key on. Once it is turn on the key for the car and it will automatically sync after 30-60 seconds. Enter the password 1234 and you are done. The phone book will also sync buy that takes a little time. Keep in mind that you may think (I did) that the system isn't working because you don't see your contacts on instrument info screen. The reason is the "apply brake before shifting" warning blocks it. Just either take a short drive or put the car in gear and you will see your contacts when you press the "mode" button on the steering wheel.
Thanks yeah I got it working. It helped that I found this seperate little book labeled audi symphony or something that had the bluetooth set up in there, not the actual owners manual. It's working great now, except when she missunderstands me..but thanks for the help.
bluetooth audi a4(2007)
hi, and you please advise how to switch on bluetooth in audi A4 (2007) ? It is somehow switched off as I can not see even sign of bluetooth close to time and date. Tried everything, handy always with bluetooth on, it was always working, but somehow in car switched off thank you!
cruciform
02-16-2011 09:31 AM
bwright19
09-29-2008 09:12 PM
bwright19
08-13-2008 07:39 PM
