55K Service
55,000 miles (85,000 km) or 1 year after last service, whichever occurs first
Engine oil / Oil filter - Change oil and replace filter.
Engine - Check for leaks.
Service reminder indicator display - Reset display.
Dust and pollen filter - Replace filter.
Snow screen for air cleaner - Clean (where applicable).
Brake system - Check for damage and leaks, thickness of pads and brake fluid level. Wiper arm pivot points - Lubricate.
Check the following:
– Cooling system - Check coolant level. Add coolant if necessary.
– Battery - Check and replace if necessary.
– Exhaust system - Check for damage and leaks.
– Engine - On board diagnosis, check fault memory. (except Audi Q7)
– Windshield wiper and washer / Headlight washer - Check adjustment and function and add fluid if necessary.
– Automatic transmission and final drive - Check for leaks.
– Manual transmission and final drive - Check for leaks.
– Tires and spare wheel - Check for wear and damage. Check tire pressure. Check renewal date of tire repair set (where applicable).
– Doors - Lubricate door hinge mechanisms.
– Sunroof - Clean guide rails and lubricate.
hindavi09
02-14-2022 11:30 AM
AudiHappy
09-02-2014 09:02 AM
jcman240
B7 Models
02-01-2014 08:27 PM
