Immobilised After Battery Change
OK before everyone tells me to reprogram the key fob, I have. Both of them.
I can happily open and closed the car this both fobs and the engine will turn over (crank) but it will not start.
I am assuming that the immobiliser is active, all I have done is replace the cars battery that finally gave up on me.
I have a BlueDriver OBD2 diagnostic scan tool which tell me there are no faults but little else without the engine running. I have however cranked the engine and noted the RPM goes up to 420 ish so I assume the timing sensor is working.
Is there something else that I should be doing to reset the immobiliser?
Any help would be greatly appreciated. Thanks.
intergalactic
03-05-2012 09:42 AM
Saleensr451
04-19-2008 10:14 AM
