05-25-2011, 11:59 PM
Level up: 64%, 55 Points needed |
Oil consumption Fail = New Piston rings ??
My car went through the oil consumption test twice. Failed with a consistent burn of about 1 quart for every 800 miles.
Audi dealer says they need to replace the piston rings and will need the car for two weeks.
Does this make sense and long term should I ditch this car before other major issues crop up. This would have been a very very expensive fix if it was not covered by the CPO which will run out in 6 months.
__________________
2007 A4 Cab CVT
08-14-2011, 11:13 AM
Level up: 21%, 79 Points needed |
oil cunsumption
I have a 2008 A4 S-Line with 40,000 miles and is now in for a test since i burned over 2 quarts in less than 10,000 miles. What year was yours and how many miles
08-14-2011, 08:51 PM
Level up: 88%, 19 Points needed |
Quote:
Is that 10,000 miles or 1,000 miles
Tags
2009, a4, audi, comsumption, consumption, due, fail, failed, makes, oil, piston, ring, rings, solved, test  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
