Oil Problems
Old 12-16-2014, 04:58 PM
Phillyphill06's Avatar
Default Oil Problems
I recently got an A4 and got an oil change that's comin up on 3k miles and my low oil light came on. I checked and it was low. Was wondering if the A4 burns through oil fast or if I might have a leak
Old 12-16-2014, 06:37 PM
imaudi5000's Avatar
i have the 2.0t in my 2008 quattro and only use mobil 1 0w-40 and do oil changes every 5k and check in between and i dont have much of a problem, not like some other people with different engines. which engine do you have? you'll just have to keep an eye on it and do the math for yourself, audi says 1qt per 1000miles is 'normal' i think. you can put a piece of cardboard under the engine when parked to see if it leaks...
Old 12-16-2014, 07:00 PM
B7Night's Avatar
Funny thing is with these engines, some use some don't. My 06 fortunately doesn't, even with 132,000 miles. Turbo's due to the higher pressures tend to use more than a non turbo'ed engine. From what I've heard oil usage is more of an issue for the B8 body, with the TFSI motor which has a little more power and much more torque than ours.
Old 12-18-2014, 03:25 PM
mhoward's Avatar
Just like B7 said, some do and some don't. Don't let it alarm you by any means. Keep a quart in your trunk and top off as necessary. And be proactive and check the oil every once in awhile when your car has been sitting for a few hours BEFORE you drive anywhere. The best time to check is in the morning before work after letting it sit all night, that way all the oil has a chance to drip back into the pan. But that doesn't mean you don't have a leak, check for that too. Enjoy!
Old 12-20-2014, 08:02 PM
Pilgrim's Avatar
Keep a record book in your car and check often. You need to have good records to track oil use. I don't worry about oil use until it's more than a quart in 1000 miles.
Old 12-21-2014, 08:59 PM
Thanks guys I went back and looked at my in voice and it was and it was 2,034 miles into a new oil change when it was low. Audi told me that it shouldn't be a problem unless it was at 1k miles. I'm keepin track and keepin an eye on the levels from here on out. And I got myself an 06 2.0t s-line
Old 12-21-2014, 09:02 PM
Pilgrim's Avatar
That ought to work just fine. A quart per 2K does show some wear or possibly some use through the turbo bushing, but it's not a real problem. Good idea to keep records of it so that you spot any change in oil consumption.
Old 12-23-2014, 03:01 PM
phosphateb's Avatar
keep a 5 quart jug in the trunk you will need it...people worry about changing the synthetic oil on these cars every 3-5k miles but mine burns 10 quarts between 10k oil changes so it always has fresh oil LOL!
Smokin Tubes
02-05-2012 10:11 AM
mykien23
12-02-2011 08:55 AM
redrhino
10-26-2011 03:49 PM
commedecargons
11-09-2005 06:43 PM
SamJamaica
06-13-2005 02:07 AM
Quick Reply: Oil Problems
