removing front bumper
alright so i tried to use the search toolbar to find out how to remove the front bumper, and albeit i havent actually look at it on the car to try and see i was just trying to get a feel for it before i try and start taking it off etc as i am planning on doing a few mods in the near future that would require me to take it off (snub mount, hid conversion, and replacing the fog lights)
if anybody had any links or know how to take it off that would be great. Also is there anything i need to disconnect or be careful of when removing it?
thanks a bunch
thanks a bunch
RE: removing front bumper
ocadam, i know that you do have to take of the front bumper in order to change the foglights unless you have small enough hands to fit back there and do it that way, which i dont unfortunately
Removing and installing fog lights
Removing
Switch off ignition and take out ignition key.
Turn light switch to position “0”.
Audi A4:
Release retaining hooks -1...4- using a screwdriver -arrow- and pull off air intake grille in bottom section of bumper.
Audi S4:
Turn bolt -1- 90° (1/4 turn).
Detach air intake grille from fog light housing in direction of -arrowA-.
Then push air intake grille in direction of -arrowB- and simultaneously disengage retaining clip -2-.
Remove air intake grille.
All models:
Unscrew bolts -arrows-.
Disengage headlamp insert and remove.
Unplug electrical connector.
Installing
Installation is carried out in the reverse order; note the following:
Engage fog light on inside at bumper.
Adjust fog lights
Tightening torque
Component
Nm
Fog light housing to bumper
[IMG]local://upfiles/12092/D95EE71B33B040808F605FEC24D9011D.jpg[/IMG]
[IMG]local://upfiles/12092/ED12DC7547D84F9D914C3A537ADE5508.jpg[/IMG]
[IMG]local://upfiles/12092/248312D7F2E94527B6C6C0A6B8B9BC81.jpg[/IMG]
ORIGINAL: harryd14
got some DIY for every1 i forgot about this site. http://www.audidiy.com/b7a4.html
