Synchronize remote key - AudiForums.com
Reply
Thread Tools Search this Thread
Old 08-23-2009, 09:44 AM
Default Synchronize remote key
Ive just bought myself an Audi 2.0T avant quattro 2005 and got a key thats not synchronized.
Ive been reading the manual for it but it doesnt seem to work, the manual says:
- Push the remote manouverbutton for unlock.
- Stick the key in the ignition and turn it on.
- Turn the ignition off and pull the key out.
- Press the unlock on the key and then the lock.
That should be it but it doesnt work, the key itself works im just using the key to unlock and start the engine etc.
Any tips?
Been trying to search on the forums but havent got any clue's on this model.
Old 08-23-2009, 05:44 PM
Does the red light blink when you push a button? If it doesn't (and maybe even if it does) then you probably have a dead battery.
Old 08-23-2009, 05:59 PM
I would change the batteries. Also when you change the batteries press the buttons on the remote with the batteries removed. I have heard that by doing this will allow the remote to sync with the car.
Old 08-24-2009, 02:17 AM
Yeah, the red light on the remote key is flashing when im pressing any button on it, but it could be a bad battery so im gona try to exchange it and try to resync the key.
Thing is that ive found multiple solutions on how to synchronize the key and i was hoping that someone had the right instructions.
Since the manual that came with the car doesnt always tell the truth in theese cases.
Old 08-24-2009, 11:34 AM
The process in the manual has worked for me. When I've disconnected the car's battery I've had to resync the key. The process in the manual works every time.
Old 02-13-2010, 11:58 PM
Post
Hi
Could anybody help me how to sync my new key? I only had one key for my Audi a6, but I lost is!!! I had to order 2 from the service. A got the keys but the car wont start!!! There is any way I can sync the key at home, or I have to tow it to the service and they will do it for me?
Thanks
Amy
Old 02-16-2010, 01:29 AM
dealer would do it for you if you bought the keys from them or at least they should.
Old 02-16-2010, 04:19 PM
Dougie Fresh's Avatar
It's probably simpler than this but it worked for me.
I took a working key, inserted it in the ignition and turned it so the radio came on.
I inserted the non-working key in the door, turned it to lock, pressed the lock button, repeated a few times. Did the same with unlocking the door and pressing the unlock button. I am not sure how many times I did each. I was just trying something I'd read on another site.
I took the key out of the door and ignition and the keyfob that was not working started working.
This was for a '07 A4.
Old 02-17-2010, 10:04 PM
Audi Tek's Avatar
Tech Certified
that is generally the sync procedure.
for B7's... Sometimes it didn't work for me and i had to do it with an audi scan tool.
Amy80, The starting of the car using a key.... that key need to be adapted to the car it was cut for by VIN via network Germany at your local dealership
Reply
Thread Thread Starter Forum Replies Last Post
Stock remote to remote start? AudiGirl92 B7 Models 1 08-31-2013 08:28 AM
will a newer flipblade remote work if i currently have a 1997 remote + key MartinCieslak1 B5 Models 15 12-11-2009 02:30 PM
2009 Audi Remote start and Remote windows krshrk B8 Models 2 09-18-2009 07:08 PM
synchronize key/remote whaaamx5 General Tech 7 11-20-2007 02:00 PM
synchronize chip ///A4 Audi A4 14 05-08-2006 06:51 PM
Tags
a4, a6, audi, b5, blinking, car, key, keys, remote, remotes, s4, sync, synchronizing, syncing, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
