URGENT-Audi A4 B8 2008 Lambda Sensor short to ground(P1115) (P0671,P0672,P0673,P0674)
Hello,
Recently my car had broken down due to not starting, my mechanic had taken a look at the car and had found that the battery had been putting out 10V instead of 12V. When i picked up the car and drove off, shortly after my DPF light had come on!! i immediately drove back to the mechanics where he had a quick look at it, i noticed he unplugged the Lambda sensor to check something and then plugged it back in, he then proceeded to scan the car with his scanner and found a lamda sensor fault (not sure if unplugging it caused an issue). anyway, i drove it back home to see if a forced regen would sort the problem out and it didn't, i then borrowed VCDS of a friend of mine which showed several errors with the DPF sensor so i replaced it and problem was solved for that but the lambda senor fault was still there.
i had the mechanic replace the lambda sensor and the fault still wont disappear, when i clear the code it comes back straight away (£165 down the drain). i have checked all fuses boot, driver side, passenger side and bonnet and they seem to be fine. i done a visual inspection of wires but can not see anything that has melted, iv also noticed after a little bit of driving around i also get another fault code P0671, P0672, P0673 and P0674 Glow Plug Circuit electrical fault, not sure if they are related in any way.
Faults
P1115 - Lamda Sensor (B1 S1) Short to ground
P0671 - Cylinder 1 Glow Plug Circuit - Electrical Fault
P0672 - Cylinder 1 Glow Plug Circuit - Electrical Fault
P0673 - Cylinder 1 Glow Plug Circuit - Electrical Fault
P0674 - Cylinder 1 Glow Plug Circuit - Electrical Fault
Any help would be appreciated.
Faults
Tuesday,05,July,2016,19:39:21:12273
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
VIN: WAUZZZ8K99A065490 License Plate:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8K99A065490 Mileage: 94930km-58986miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGC) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3177
Revision: --H01---
Coding: 0104002C18072018
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022 A01005
ROD: EV_ECM20TDI03L906022.rod
VCID: 62CD94C87560402E08-8036
4 Faults Found:
5110 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 00 [175] - Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 08:25:15
4984 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [101] - Electrical Fault
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 19:36:15
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [101] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 19:36:15
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [101] - Electrical Fault
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 19:36:15
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 160500
VCID: 78F9D6A0CBFCBAFE46-802C
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 031100
VCID: 30692E80630CA2BECE-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
4 Faults Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 17
Reset counter: 234
Mileage: 75956 km
Time Indication: 0
Date: 2014.06.26
Time: 18:07:52
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 94846 km
Time Indication: 0
Date: 2008.04.04
Time: 20:02:07
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 94899 km
Time Indication: 0
Date: 2008.04.06
Time: 08:59:20
02811 - Control Module for Electronic Steering Column Lock (J764)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 94916 km
Time Indication: 0
Date: 2008.04.07
Time: 02:59:19
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0124.06.080694
Coding: 34040000
VCID: 428D7448DDA0202E28-8016
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000176384
Coding: 260050914034AF000001000000001D0D001D03080001014100 0000
VCID: 2F6B2DFC7E32BD46D7-807A
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 040708 H05 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD173G0R
Coding: 30363434363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C710AB0B74456DE62-8068
Crash sensor for side airbag; driver side:
Serial number: 6334MSME2A637838K
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME3B314F2CP
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME7D702129I
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME7D703277O
Crash sensor for front airbag; driver side:
Serial number: 63732SME7D282F67G
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME6C303705-
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HG2000EO
Coding: 000012
VCID: 3D7707B4A45E5FD655-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 99563P478
Coding: 2F04080002002600010000
VCID: 316F2B846806ABB6C1-8064
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0862981AD
Coding: 000303
VCID: 46856858F1881C0E04-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000007364412
Coding: 011002204001410001
VCID: 40897E40D3AC323E3E-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112712488
Coding: 011B062200390440002001
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
3 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 52
Reset counter: 16
Mileage: 75064 km
Time Indication: 0
Date: 2014.06.13
Time: 23:27:48
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 94
Reset counter: 163
Mileage: 76991 km
Time Indication: 0
Date: 2014.07.12
Time: 20:57:27
03123 - Terminal 30 - 2
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 94899 km
Time Indication: 0
Date: 2008.04.06
Time: 08:59:20
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010102
VCID: 6ED5F0F8B9B8F44E9C-803A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000007388975
VCID: 3F8B7DBCAE524DC647-806A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000163780
Shop #: WSC 00000 000 00000
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 3461229057149E9EAA-8060
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 C HW: 8T2 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1085151
Coding: 0502008201018D000359070000
VCID: 387916A08B7C7AFE86-806C
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 131
Mileage: 94296 km
Time Indication: 0
Date: 2008.03.04
Time: 01:06:18
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000100094522
Coding: 010002204001210001
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000100105954
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 A HW: 8T0 862 335 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005013400
Coding: 0010320
VCID: 387916A04B7C7AFE86-806C
End-------------------------(Elapsed Time: 02:48)--------------------------
Ross-Tech: Home
Revision: --H01---
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 08:25:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 19:36:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 19:36:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 94928 km
Date: 2008.04.08
Time: 19:36:15
Coding: 160500
Revision: 00002001
Coding: 031100
4 Faults Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 234
Mileage: 75956 km
Time Indication: 0
Date: 2014.06.26
Time: 18:07:52
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 94846 km
Time Indication: 0
Date: 2008.04.04
Time: 20:02:07
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 94899 km
Time Indication: 0
Date: 2008.04.06
Time: 08:59:20
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 94916 km
Time Indication: 0
Date: 2008.04.07
Time: 02:59:19
Coding: 34040000
Coding: 00FD11
Coding: 025028
Coding: 000012
Coding: 000303
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 52
Reset counter: 16
Mileage: 75064 km
Time Indication: 0
Date: 2014.06.13
Time: 23:27:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 94
Reset counter: 163
Mileage: 76991 km
Time Indication: 0
Date: 2014.07.12
Time: 20:57:27
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 94899 km
Time Indication: 0
Date: 2008.04.06
Time: 08:59:20
Revision: S1900000
Coding: 0203010102
Coding: 0000004
Component: Display
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 131
Mileage: 94296 km
Time Indication: 0
Date: 2008.03.04
Time: 01:06:18
Coding: 0010320
