Bluetooth Streaming Audio
Old 08-03-2016, 01:55 PM
brandnew__eyes's Avatar
Originally Posted by elitemike
Did you use the original ipod cable?? I have the Viseeo WMA1000 and the audi quality isn't always the best. I'd be willing to spend 30 bucks on the updated one if I can get away using the original cable by tweaking the hidden settings.
Yes I am using the original cable given to us by audi that connects directly to the car, and the blue tooth module has a 60 pin port on it. Once in a blue moon the music will skip on me, but overall I'm super pleased with the way it works.
  #62
Old 12-09-2016, 10:49 AM
Tuinui's Avatar
Sorry for going off Topic but
I have a 2006 Audi A6 with multi CD player I would like to exchange the CD player to a USB port so I can play multimedia through the head unit does anyone have any information that would be useful for me as I've tried and lots of Jesus the only option was a radio transmitter plugged into the cigarette lighter which is ok but this is lot of distortion
Thank you for any usefull information
  #63
Old 01-13-2017, 05:14 PM
Keirowyn's Avatar
This is great if your hidden menu is enabled...mine apparently is not (holding down the buttons does not bring it up in my 2011 A4), and I don't have the cable / software to enable it.
So I guess buying the "hacked" cable from a2dp4audi.com is the cheaper of the two options.
  #64
Old 01-16-2017, 01:54 PM
nleco's Avatar
What are you trying to use? the tune2air BT module? I use the original cable, and don't recall turning on any menu. it works well with mine. I also have a 2011 A4.
  #65
Old 01-16-2017, 02:58 PM
Keirowyn's Avatar
I bought the $25 bluetooth receiver from Add Bluetooth A2DP Streaming to your Audi - A2DP4AUDI - Audi Bluetooth Adapters
Trying to use it with the standard ipod cable that came with the car and it says there is no device attached or something.
  #66
Old 07-21-2017, 04:29 PM
Sound's Avatar
i am using Bluetooth a2dp adapter from www.sound2air.com they have for 2G MMI and 3G MMI. what you need is just plug it to AMI port and thats it. you can stream music via bluetooth to your
  #67
Old 07-28-2017, 01:48 AM
ellain20's Avatar
Default music stream
a friend gave me this tune2air BT adapter. It automatic call switching between music and phone. I have no problem using it.
  #68
Old 09-11-2017, 04:33 AM
Grace1991's Avatar
We have the same problem with this AMI, MMI thing to my 2011 A4 Premium Plus. Since I already have this 30-pin iPod connector, my friend recommend this A2DP bluetooth adapter Bovee WMA1000 from viseeousa. From then on, I can stream music wirelessly from my phone library and spotify, and it automatically connects to my phone whenever I enter the car and the good thing is it supports both iPhones and Androids. Its very easy to use just simply plug the device and you can play music and control the steering wheel, etc....
  #69
Old 09-29-2017, 12:39 PM
SkyGuy9's Avatar
I got a Bovee 1000 and it works great its a small adapter. Plugs into the adapter in the glove box. My car is a 2010 A4
Amazon Amazon
  #70
Old 01-16-2018, 04:41 AM
Linus Flavius's Avatar
Default hello everyone, how do i code my b8 wihout nav
Hey i have a trouble, my steering wheel button for speaer dont work, because i make some mistakes. I also delete the debug.txt file. So now when i connect to bluetooth, my button do nothing. If can help me someone to recode with vcds. Thanks
anthonygar08
08-24-2017 10:28 AM
HDR78
B7 Models
04-15-2014 12:58 PM
apples
11-15-2013 09:21 AM
Audi_FTW
11-22-2010 03:07 PM
AM10
07-23-2010 02:40 AM
Quick Reply: Bluetooth Streaming Audio
