Rear driver side door will not onlock with remote
Old 07-29-2015, 04:49 PM
steve-sline-exec's Avatar
Default Rear driver side door will not onlock with remote
Hi I can hear the solenoid opening AND locking the door via the remote but it will not open from the outside using the external handle. If I then pull the internal lever , the door opens and the external handle can then also open the door if I close it. I can lock the car using the remote but have to pull the internal lever every time I want to open it. The child lock is not on.
I have a vag code of 02115 locking unit for central locking 008 Implausible signal. Any help appreciated. Thanks
Old 07-29-2015, 05:50 PM
skazzor's Avatar
Exclamation Door Issue,
I have a similar issue with the front drivers door, it will lock and unlock but will not open when i pull on the outside handle and will open when i pull the internal handle however there are some occasions when it will open with the outside handle,
Old 08-01-2015, 06:04 PM
Thanks skazzor for your uuummmm reply but not exactly helpful, apart from highlighting your own problem which i'm SURE you could of posted yourself but at least you have replied . I am staring to notice a trend on here , if you mod then lots of replies if you have a problem then go somewhere else. Thanks (YES for all you smart as##s you caught me on a bad day).
daboss085
11-15-2012 08:27 PM
Olezhka
02-15-2011 09:24 PM
Mixmastermike
10-12-2008 02:30 PM
ducatheart
07-15-2008 12:43 PM
Quick Reply: Rear driver side door will not onlock with remote
