Chop Shop Show off your designs here. Or post to have your fellow members do some photo shop work to your ride.
A8L tiptronic automatic to manual 6-speed 01E
Old 02-12-2016, 12:35 AM
glenbjackson's Avatar
Default pics fixed
changed over to photobucket and added some pics of the lathe!!!
Old 02-14-2016, 12:28 AM
twopedalwarrior's Avatar
keep up the good work, seems I only ever come here for this thread now days
Old 02-17-2016, 12:20 AM
thanks bro! I will try to keep it interesting over here so you'll keep coming back
Old 02-17-2016, 11:32 PM
Got the Audi splined clutch disc. They are cerametalic. Unsprung though but I won't be launching or anything so tranny should still be able to hold up.
Old 02-18-2016, 09:46 PM
be gentle with the break in on the clutch, but youll have fun. Did you look at a fidanza or anything else similar?
Old 02-19-2016, 12:56 AM
I did and others too. But the reason I went with this type is it's re-buildable, which im really big on. Though I wouldn't mind have a sprung disc they wont fit stacked and that was another reason, more surface.
AWWWHHH yes !!! and I just remembered the biggest reason... price and parts. there is surplus from circuit racing on ebay.
im looking at fidanaz now... their prices don't seem bad though.
Old 03-31-2016, 02:59 AM
Default long times ahead..
so after reading of the weakness of the 01E with a naturally aspirated v8 hauling a small body(http://12v.org/urs/charlie_smith/01E/v8info/index.htm) there's no point in attempting the d2 body, even with it being aluminum.
so my plan is to sacrifice a spare 01e front diff section get it ready for a mold at a local casting plant. Add clay where needed, draft, reference points, etc.... I'll have it poured in steel, yeah I know heavy but I figure once coupled with mid section and rear diff section it'll weight about the same as the auto in there now.
The monarch will be able to swing the casting.
ill face the front and rear to length, use the reference points on the mold to set the input shaft and with a template get the front bell housing bolt pattern. once I have those holes ill use a jig. Set the real 01e on the jig which goes into it at a couple of bell housing bolt holes AND the input shaft, center it on the lathe for the remaining rear holes and internal shafts(individually lllloooonnng and slow),remove the original from the jig, keeping jig in the chuck and put the casting on the jig. Then drill, true it by boring then ream it. Good thing is with the front diff section of the 01e all the bearing surfaces have an insert, so I might not even need to ream. finally once I have the front and back done ill make a large 90 degree angle jig and do same with side holes.
and then run it... easier typed than done
  #18
Old 06-16-2016, 01:01 PM
Default numbers
Most measurements from average of 3 or more readings. This is a draft for a custom flywheel with Tilton 7½" button clutch between a 01E and a 4.2 v8 40v engine with the 8 bolt pattern.
  #19
Old 06-17-2016, 01:28 AM
Default sorry for bluriness
heres pic with good quality
Attached Thumbnails A8L tiptronic automatic to manual 6-speed 01E-clutch-diagram.jpg
  #20
Old 06-29-2016, 02:27 AM
did some measurements ill have to add a pocket for the pilot bearing into the flywheel. input shaft doesn't reach crank.
Quick Reply: A8L tiptronic automatic to manual 6-speed 01E
