1994 Cabriolet Rear Speakers Dead
I am trying to fix the rear speakers in my 94 Cabo. I have the Gamma radio and all connections seem fine on the back. I have also checked the rear amplified speakers for loose wires and the 7.5 amp fuses are fine as well. If anyone has experienced the same issue or has any ideas it would be greatly appreciated.
Thanks
Thanks
I ended up having to dump the rear factory speakers in my 5000SQ. I found some Pioneer 6" that fit in the factory mount with a little modifying of the factory unit. See if you can hook up another speaker to the connections temporarily to eliminate the possibility of the amp not putting out any juice.
I ended up replacing my factory radio with a newer Pioneer unit that has an AUX-in port on the front so I could hook up my Phone. Replaced the dinky front speakers with some Pioneer units that were made to replace them. Sounds a HELL of lot better.
AmadiAudiA4
08-15-2008 11:31 PM
