AudiForums.com
Go Back   AudiForums.com > Audi Models > Classic Audi
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 05-15-2009, 11:49 PM
Points: 2,967, Level: 33
Points: 2,967, Level: 33 Points: 2,967, Level: 33 Points: 2,967, Level: 33
Level up: 45%, 83 Points needed
Level up: 45% Level up: 45% Level up: 45%
Daily Activity: 1.9%
Daily Activity: 1.9% Daily Activity: 1.9% Daily Activity: 1.9%
Default 4000S. I can't find seal anywhere
I have a 1984 4000S 2WD with the 4 cyl engine and found a seal in between the air flow meter and the air filter housing that was nearly gone from all these years of degrading. It seems to made of a cross between cork and rubber. I can't find this even at Shokan.com, which my mechanic tells me is the largest Audi salvage yard in the country. This seal is something I would expect to be commonplace since, like most seals, is one of the few things in an engine that is absolutely guaranteed to need replacing. Can someone help me, even if it's just a suggestion on how to custom make a seal?
http://s733.photobucket.com/albums/ww332/atwooddav/
The left picture is the top of the air filter housing. In the center is the top of the air flow meter with the fuel distributor on attached. The last image is the bottom of the air flow meter with the partial seal next to it.
Old 05-18-2009, 01:39 PM
Points: 6,483, Level: 52
Points: 6,483, Level: 52 Points: 6,483, Level: 52 Points: 6,483, Level: 52
Level up: 67%, 67 Points needed
Level up: 67% Level up: 67% Level up: 67%
Daily Activity: 1.1%
Daily Activity: 1.1% Daily Activity: 1.1% Daily Activity: 1.1%
Call Chris at Force Five in concord NH 603-223-6700
__________________
1997 A6 Avant with over 250,000 miles - Now dead
2007 Dodge Grand Caravan SXT - 2002 Dodge Caravan
1999 Mercury Sable Wagon w/48K miles
1919 Model T Ford Beach Wagon - AKA Woodie
Old 05-19-2009, 08:38 PM
Thanks, I'll give it a try. I also needed an air boot that I can't find anywhere, so I'll ask about that too. At this point, if he doesn't have the seal, I'll just have to trace the shape on some gasket material.
Old 05-19-2009, 09:13 PM
Midniteoyl's Avatar
Points: 4,337, Level: 41
Points: 4,337, Level: 41 Points: 4,337, Level: 41 Points: 4,337, Level: 41
Level up: 94%, 13 Points needed
Level up: 94% Level up: 94% Level up: 94%
Daily Activity: 1.8%
Daily Activity: 1.8% Daily Activity: 1.8% Daily Activity: 1.8%
You could just head done to the local parts store and pick up Sensor Safe Silicone sealant...
__________________
Jim
'96 A6Q - 140K already!!
Old 05-20-2009, 12:06 PM
I already considered a sealant that's applied the same way as toothpaste on a brush, silicon being one of them, and decided I want to maintain the same material, especially in case I ever have to take it off again. If that happens, I'll have to scrape off both the air flow meter (no problem) and the air filter housing, which is made of plastic (scraping action could damage plastic).
It doesn't matter anymore. I called Chris, had no luck, so I've already cut out a gasket from a roll of cork I picked up from the hardware store.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
