AudiForums.com
Go Back   AudiForums.com > Audi Models > Classic Audi
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 03-13-2012, 12:57 PM
Exclamation 80 coupe 2.8 leaking oil
Hey there, I have a 1993 80 coupe 2.8 that is leaking oil. Aint got a clue where the leak is coming from but she is defo leaking She also has a habit o dying when she goes too slow, especially round sharp corners. Starts agin no probs tho. Any help at all would be so greatly appreciated.
Old 03-17-2012, 09:06 AM
88A5TQ's Avatar
Points: 4,372, Level: 42
Points: 4,372, Level: 42 Points: 4,372, Level: 42 Points: 4,372, Level: 42
Level up: 11%, 178 Points needed
Level up: 11% Level up: 11% Level up: 11%
Daily Activity: 2.8%
Daily Activity: 2.8% Daily Activity: 2.8% Daily Activity: 2.8%
Question dead forums
I'm more familiar with older audis but you should start by looking under the engine for "fresh-looking" oil residue if its already pretty grimy under there. If it all looks the same take brake cleaner spray and a rag and clean it up. Drive a little bit and check for new oil and you will have a general idea of where the leak is. It's possible you are burning oil too instead of leaking.
As for the stalling, Idk is your fuel pump new, o2 sensor newish (good gas mileage?), does car do it everyday when engine is warm only or both warm and cold engine, does it do this regardless of temp outside? New spark plugs, cap, rigor, wires. Idk since I don't know the car. Is your oil pressure warning light coming on? Have you ever run fuel injector cleaner through those old injectors?
Lastly, don't put all your eggs in one basket and go to the audiworld forums too. This forum can be quite dead sometimes in this subsection.
__________________
1988 Audi 5000CSTQ, TAP, 2.5cat-back K&N CAI, 2.5 bar spring and bolt mod, AFR'd to 18 psi, IC sprayer, AEM W/M
Reply
Tags
28, 80, audi, coupe, leak, leaks, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
