85 UR quattro
Old 09-04-2016, 05:56 PM
team illuminata's Avatar
On a roll now
Jumped the fuel pump relay to drain some old fuel.
image by Team Illuminata Motorsport, on Flickr
New filter
Had to come up with a way to mount this thingy-me-jig as the mounting tabs were long gone.
Turbo inlet. Tight down there.
and fuel distributor
Our parts shelf is look quite bare now.
  #212
Old 09-10-2016, 01:54 PM
Today's progress. Hopefully not this weekend's progress.
Connected the fuel lines to the warm up regulator.
New fuel filters:
There really isn't much left to do. At least to get it running:
CRANK BOLT
THROTTLE BODY
WIRING ISSUES
SPARK PLUGS
TRANS FLUID
Then once it works:
COOLANT
REAR BRAKE LINE
BLEED BRAKES, CLUTCH
PS STEERING FLUID
WIPERS
BUMPER
HEADLIGHT
INJECTOR BLOWER
TIGHTEN CONTROL ARMS
ADJUST SHIFT LINKAGE
ALIGNMENT
DETAIL
Then we put it away for the winter.
  #213
Old 09-21-2016, 01:38 PM
So, assembly continues as we edge nearer to the momentous day when it drives itself off the hoist, hopefully down the road and not into winter storage.
Got the throttle body cleaned, adjusted and back on.
Then had to fix the inlet air temperature sensor.
Fortunately our 83 has one that looks like it was a replacement once. Ohms check check out too.
A bit of electrical shenanigans and it's in.
Then there was nothing left to do but call my Audi expert, Werner then fire it up!
https://www.youtube.com/attribution_...m-upload_owner
Doesn't idle yet and still needs coolant but we had a little celebration anyway.
  #214
Old 09-30-2016, 03:26 PM
As this project is sort of wrapping up we started another one we thought you might like. Introducing the Audi UR Quattro Rally Build.
transformation by Team Illuminata Motorsport, on Flickr
  #215
Old 10-09-2016, 11:49 AM
So, a lot of work but not a lot of updates. Here's why.
Bled the brakes.
Reinstalled the grill and the bumper.
and put it back on all fours for the first time in years.
Then got it to idle and run quiet.
Then drove it off the lift.
Then took it for a drive.
Then stood back and admired it
Happy birthday to me!
  #216
Old 10-24-2016, 10:29 PM
Sorry about the lack of updates. Got distracted by some work related events not the least of which was attending LSPR with our 911 and other assorted old rally cars.
14695439_1305247436187424_7489908328833138150_n by Team Illuminata Motorsport, on Flickr
Since I got back I haven't worked on the car but taken every opportunity I could to drive it. This included a funeral, a couple of cars and coffee events, an open house and running to Autozone for parts for our ailing Allroad.
I'd forgotten how much I enjoy driving this car and how much attention it gets. I'm going to try to enjoy it as much as possible before it goes away for the winter. It drives very well, is smooth and quiet but does have a slight hesitation under load though it pulls strong. I can figure that out and put the remaining few parts back on this winter. For now LET"S DRIVE!
  #217
Old 10-25-2016, 07:54 AM
dave944's Avatar
Check the gap on the spark plugs and make sure it's correct. I'm sure you put new ones in it. I think it's supposed to be 0.028. I had a similar issue with my 87 5000SQ (nearly identical engine to yours) but it turned out to be a glazed spark plug in my case. They were fairly new but somehow a couple had glazed for some reason. I'd check for that too.
Hoping to score me one of those GT Quattros someday soon. Yours is NICE!!!
  #218
Old 10-26-2016, 08:50 AM
Thanks. Plugs were new before the tear down. Gas checked prior to re-installation but I'll have a look at them again.
  #219
Old 11-03-2016, 12:20 PM
Been looking for opportunities to show of the car and have some fun with it before we run out of season.
The demise of our A3 left us with some 17" BRAID Fullrace A wheels and 225 tires lying around and with the help of the spacers that our ALLROAD doesn't need with it's winter wheels it soon became obvious what we must do. Throw them on the quattro!
This is only for fun mind you. They are a little contemporary and the 225/45-17 tires are about an inch to tall but it was well received in this state at our local meet Saturday.
You can feel the extra weight and diameter when driving and there is s slight rub somewhere on full lock but they are about the same diameter as the package we are planning to use on our 83 build so worth the trouble. 15" BRAIDs go back on soon.
The car is starting to srtuggle to start again now. Runs great once warmed up exept for a slight hesitation around 4000 rpm. Maybe the cold start valve? It is also pissing out hydraulic fluid still. We replaced everything around the bomb except the pressure switches so we suspect those. New ones are on the way.
We have also been tidying up the mess we gad left over from the project. This consists of mostly parts that need to go into boxes and parts that still need to go on the car.Tok care of inventorying and boxing parts and installed the plastic underbody stuff.
So just the cruise control actuator and injector blower to reinstall when we get chance. Holding off for now until we diagnose the starting issue though.
  #220
Old 02-15-2017, 06:43 PM
It's been winter for too long already so no driving the 85. No working on it either as our 83 rally build and wheel sales have been keeping us busy. We have been picking away at the hydraulic system leaks however. We easily sourced some new pressure switches for the hydraulic bomb and quickly replaced the one on the side. However we did manage to disconnect a wire in the process.
by https://www.flickr.com/photos/team_illuminata/, on Flickr
The one underneath was a different prospect requiring us to access it from below. This, of course, took many, many weeks to get round to until recently when we finally drove it onto some ramps in the showroom.
where it sat for another couple of weeks till we had time to crawl under it. It soon became anther classic Audi "unscrew the simplest thing, if you can" project until we found just the right 24mm deep socket to get the switch off. At first we tried loosening the bomb from it's moorings but you cant undue these two nuts even though you can see them:
Finally found a thin wall socket that fit.
This still left the wiring issue to fix.
Think this is where it came from.
This puppy cost $35! Well, it was free, but we had to buy $35 worth of zip ties to liberate it from the box of 100 we were supposed to buy.
Soon had it on and back on the switch.
Of course we can't tell if it's solved the leaks till we drive it and it's still too salty outside. Never mind, now we can fix the leaky rear diff. However, this involves putting it on the lift and you now how long it took to get it off there last time! Wish us luck.
Quick Reply: 85 UR quattro
