Bleeding cooling system
I have a 1988 90 Quattro and little or no heat comes from the vents. I recently replaced the water pump and thermostat because of an overheating condition. I did have heat before that. I tried to bleed the air out using the bleeder that is in the heater hose at the firewall. I get semi-warm air. But the next day it is cold again. It does not seem to have a heater valve.
My question is: What is the proper procedure for bleeding the cooling system on that car ?
RE: Bleeding cooling system
check for a screw on top of the radiator ,,, if you got one then thats where the bleeding should take place .... if you dont have one there than heat up the car (let it run till temp rises) and open up the reservuor cap to let of some pressure
Provided that I have bled all air from cooling system. Both heater hoses seem to be hot. Vents still blow semi warm air. Temp gauge reads low. Is there a door or flap that may prevent air flow through the heater core and into the cabin? Is it vacuum operated? How do I get to it without the use of a saws all? It is getting too cold in New England for no heat.
when u do run the car, and there is warm air coming out, and the car is warmed up. first check that the tubes of the heater core are hot. if they are warm, then rev the engine couple of times high. and u should experience burst of hot air, if not. u probably have a clog in the system. if the tubes are hot, then u probably broke the cable, that turns a door for the heater core.
According to bentley, to blead the system unscrew the bleeder valve on the heater hose approx. 2 full turns and the bleeder valve on the coolant pipe on the back side of the engine. the second valve is located just behind the driver's side bank on the coolant pipe next to the cps.
People, friends, buddies, help! I have a problem. Under the cap of expansion tank there is abundant bleeding of coolant when the engine reaches about 90C and further. Some say it's about thermostat. Is that so? If it is, which thermo to buy. And, btw what is normal summer temperature of turbo diesel engine?
