Fuel Accumulator/fuel line issue
Old 01-18-2007, 08:50 PM
malamutt28's Avatar
Default Fuel Accumulator/fuel line issue
Okay, 1990 Audi 100 2.3 non-quattro has a fuel leak at the fuel accumulator. There is a small bit of steel tubing at a 90 degree bend when it comes our of the accumulator and then transitions into the rubber fuel line. Does anyone know how to fix a leak in the "elbow" of the small steel tube? It has a crack and I am unsure where you can find the tube and/or fittings to secure it to the accumulator & fuel line at the other end. Please HELP! Thanks
Old 01-18-2007, 09:04 PM
malamutt28's Avatar
Default RE: Fuel Accumulator/fuel line issue
this is the part on one of the outlets is the 90 degree tubing that has the crack in the elbow
[IMG]local://upfiles/23578/3F4AFB6DAF2740548F44CB44E1A804A0.jpg[/IMG]
[IMG]local://upfiles/23578/E0A8B3957C4A4ACC9648DF8F60411DEC.jpg[/IMG]
Old 01-18-2007, 10:14 PM
TommyL's Avatar
Best thing to do is look harder to replace, but if not you have a other option.
JB Weld?
Old 01-19-2007, 04:59 AM
InExile's Avatar
yes jb weld would be an easy quick fix ... but the best thing would be to replace the fuel lines ... use some steel braided one high pressure ... you can also use the aluminum ones if you would like ... check your local parts stores for fuel lines or a quick seach on google gave me this http://www.northernautoparts.com/Pro...FRdkSgodpXeBHg
Old 01-19-2007, 07:36 PM
malamutt28's Avatar
Thanks for the input. JB Weld must be the miracle quick fix as you are the 4th person to suggest that including our local Audi dealer!
The problem seems to be in the compression fitting, getting it to seal. I guess that is where the JB Weld will come in. Thanks again...
skihigh2299
10-11-2015 05:54 PM
skihigh2299
09-25-2015 12:09 AM
vtraudt
05-09-2011 11:08 AM
sljone
04-02-2010 06:00 PM
greg_audi
09-12-2008 03:37 AM
Quick Reply: Fuel Accumulator/fuel line issue
