AudiForums.com
Go Back   AudiForums.com > Audi Models > Classic Audi
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 08-05-2009, 01:46 PM
Default Help with Headlights and Turn signals on 87 4000s
My rear turn signals work, but they are fast. the front turn signals do not work. the headlights werent working, so the dumbass before me put a toggle switch under the hood for the headlights. could this have something to do with the turn signal relay? any and all help is appreciated.
Old 08-06-2009, 12:42 PM
Points: 6,483, Level: 52
Points: 6,483, Level: 52 Points: 6,483, Level: 52 Points: 6,483, Level: 52
Level up: 67%, 67 Points needed
Level up: 67% Level up: 67% Level up: 67%
Daily Activity: 1.1%
Daily Activity: 1.1% Daily Activity: 1.1% Daily Activity: 1.1%
Start looking for a bad ground at the front -
Then get a manual with a wiring diagram - looks like you have a bit of work ahead of you.
I have the Bentley and Hayes Repair manual for Audi 4000, 4000S, and 4000CS that I'd consider selling
__________________
1997 A6 Avant with over 250,000 miles - Now dead
2007 Dodge Grand Caravan SXT - 2002 Dodge Caravan
1999 Mercury Sable Wagon w/48K miles
1919 Model T Ford Beach Wagon - AKA Woodie
Old 08-09-2009, 05:08 AM
Sounds like the problem is your switch in the steering column. I'm starting to have the same problem (no low beams, only the high beams for headlights) and my left turn signal is starting to spazz out. I know for a fact my switch is going. If you're on a budget, you could pull the switch and clean it/try to fix it. Otherwise, I think Force 5 has them for about 20 bucks.
__________________
Owner of a Pearl White 1989 Audi 200QT. Pics to come soon.
Old 08-09-2009, 09:40 AM
Send a message via AIM to damianf6
im having the same problem with my 1993 90 CS. the low beam do not work. and i have a dim high beam. and the left driectional worked until the other day. now it buzzes when i try to turn left. im def gonna look into replacing the switch
Reply
Tags
4000, 4000s, audi, beam, bolt, column, forums, headlight, headlights, low, signals, size, steering, turn, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
