06-16-2011, 02:09 PM
Points: 11,795, Level: 71 |
Level up: 37%, 255 Points needed |
2.7T - data log numbers
I had my 2.7T custom tuned (aggressive tune, 93 oct, stock configuratoin; no data logs) and later removed the pre cat and main cat (same tune). The car felt VERY strong, and logged data confirmed:
Max MAF: 250.5 g/s at 6400 rpm
Max Torque: 458.6 Nm at 3000 rpm
Max HP: 303.9 HP at 6480 rpm
Max Boost: 18.1 psi at 3000 rpm
With the cats removed, we retuned the car yesterday, but did NOT manage to get any improvements:
Max MAF: 256.8 g/s at 5760 rpm
Max Torque: 438.1 Nm at 3200 rpm
Max HP: 296.3 HP at 6920 rpm
Max Boost: 20.2 psi at 3680 rpm
The 'butt meter' confirms. Maybe a little more lively above 4k rpm, but less 'torque hammer' around 3k.
What are the numbers out there for the 2.7T (VAGcom logs)?
Giac, APR, etc for Stage 2 (? gutted pre cat and eliminated main cat, rest stock)?
Why are we not seeing improvements that I expected from the surely reduced backpressure and increased exhaust flow?
What is the next bottleneck that I an tackle without spending much?
Larger turbos have to wait until year end
__________________
1998 Audi A4 1.8T Quattro, dark blue, K03/K04+ hybrid, Carbonio CAI, APR Inlet Tubes, APR R1 diverter, GIAC PC16, 31lb inj, 20x6x2.75 FMIC, 185 g/s MAF flow, DP 'sport cat, Milltek CB Exh, Podi Boost Gauge, 17" OZ F1 225/45-17, PowerSlot, Hawk Pads, SB Stage III clutch; 1996 Audi A 2.8 Quattro auto, stock, 2002 AR 6 spd lower wider Stg2 cust
08-27-2011, 03:53 PM
Level up: 94%, 6 Points needed |
Max MAF: 277.6 g/s at 5603 rpm
Max Torque: 458.3 Nm at 3200 rpm
Max HP: 320.8 HP at 6900 rpm
Max Boost: 18.1 psi at 3100 rpm
Tuned by MTM, pre cat is out, running on 98 oct everythingelse stock.
08-27-2011, 06:07 PM
VERY nice! good to see that there is quite a bit of room left on the stock motor.
LOVE your torque number (already like mine a lot).
__________________
10-26-2011, 03:09 AM
Level up: 54%, 23 Points needed |
coll dude
good to see these..............its......its really cool
09-02-2012, 10:54 AM
Level up: 37%, 95 Points needed |
Necro bumping this thread ....where are you guys getting these numbers from dyno?
__________________
wanted allroad,s6 or 4.2 doorblades
2001 A6 2.7t slush box
09-02-2012, 11:35 AM
Quote:
Data logging:
Vagcom, ECUx, nefmoto logger, etc.
They are all in your ECU.
Great way to check out the effects of those 'feel good mods' (like "really hot air intake", K&N filter, "Darin Intake mod".
But also a must for fine tuning custom tunes (your tuner will tell you what and how to log).
__________________
09-03-2012, 09:26 AM
Yeah I just logged my car for the first time a couple days ago.... Results where not so good
__________________
09-03-2012, 09:44 AM
Post results!
the more logs we have the better.
Particularly MAF, IAT, (Torque if you have).
__________________
09-04-2012, 08:56 AM
Where should I post them in the main forum or right here?
__________________
Tags
2006, 27t, a6, apr, audi, cats, custom, data, fueling, kit, logging, numbers, precat, stage, tune  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
