Address 01: Engine Labels: 078-907-551-AZA.lbl
Control Module Part Number: 8D0 907 551 B
Component and/or Version: 2.7l V6/5VT 0004
Software Coding: 06651
Work Shop Code: WSC 00000
VCID: 295702B5F98B
8 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low (this one is from disconnecting MAF)
P0102 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
Readiness: 0010 1101
I know i need to pull plugs..etc now
Could this be as a result of the Intake manifold not being put on right? I did put spacers on...maybe they should come off?
