02-16-2012, 03:59 PM
Level up: 76%, 24 Points needed |
Turn Signals Not Working - Audi A4
To Whom It May Concern,
I have a 1998 Audi A4 with almost 130,000 miles on it.
The other day, I got in the car to go to work, and I noticed that my turn signals did not work. The hazard lights button does not work either.
I replaced the fuse for the turn signals, but they still do not work.
Everything else works: dashboard controls are functioning, headlights, and rear lights work, everything else works fine.....
How do I get my turn signals working again?!?!?!
Thanks,
Tim
02-18-2012, 08:57 PM
Points: 13,042, Level: 74 |
Level up: 48%, 208 Points needed |
Change the hazard switch - very common, well-documented problem on these cars.
__________________
ImTheDevil / 1999 30vqm
02-19-2012, 10:39 AM
Level up: 14%, 43 Points needed |
Thanks,
Tim
did you check the blinker fluid? this might just fix it.
Blinker Fluid [BF-01] - $8.99 : KaleCoAuto, Hard to find automotive items!
Tags
1998, 28, 98, a4, audi, blinkers, doesnt, drivers, rear, side, signal, switch, turn, work, working  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
