2003 2.7T -difficult initial cold start then fine*
Old 04-13-2015, 03:35 PM
dvdvsx52's Avatar
Default 2003 2.7T -difficult initial cold start then fine*
Hello,
A problem has just started with my 2003 2.7T. Initial "cold" starts require 6 to 10 turns of the ignition key to get the car to idle without stalling. After the lucky "start", the car idles very rough for about 2 minutes - pressing the gas during this time actually has the effect of dropping RPM's toward stall and then it revs go up.
To make it even more peculiar, once the car is running it will restart perfectly with a single turn of the key unless left to sit for a long period (e.g. 5+ hours).
Has anyone had this issue and if so, how did you resolve? Anyone have any thoughts on what this could be?
Thanks!
Old 04-22-2015, 12:42 PM
dvdvsx52's Avatar
Default ???
Is anybody on these forums, did I not write in the correct section? Any help at all would be appreciated.
Old 08-13-2015, 07:23 PM
gtg33k's Avatar
I have same prob if it makes you feel better.
Don't have a solution or answer though
Going to try new spark plugs.
Old 11-11-2015, 01:09 AM
bschnucky's Avatar
Same issue here
dvdvsx52
04-13-2015 03:28 PM
korndmc
08-02-2012 03:59 PM
spook_32
10-14-2011 05:09 AM
felixvg
01-07-2010 01:07 PM
Quick Reply: 2003 2.7T -difficult initial cold start then fine*
