Still misfiring
Old 09-27-2014, 08:59 PM
cncbamf's Avatar
Default Still misfiring
I have a 99 A6 2.8L, I've replaced the coil pack, the spark plugs, and the air vent tubing. I get the following codes:
P0157 o2 circuit low voltage bank2, sensor2
P0300 random misfire
P0303 cylinder 3 misfire
P0305 cylinder 5 misfire
My next step is checking the ignition coil since 3&5 are are the same wire. My question is what am I checking for and how? The manual I've been doing my work from is for passat/audi a4 but covers the 2.8L but the wiring diagrams/schematics are a little different. Also is there a fuse or something else I should be checking.
Thanks for the help
Old 09-28-2014, 06:08 PM
CRAZYHAWK's Avatar
Old 09-30-2014, 07:46 PM
cncbamf's Avatar
It does at low rpm, after 2 1/2 to 3ish it seems fine. Every once in a while it will in higher gears but still at the lower range of rpm.
Old 10-03-2014, 02:01 PM
cncbamf's Avatar
figured it out, the new coil pack I got was bad the pack that controls cylinder 3 & 5 was a couple thousand ohms out of tolerance. Just got a new one from Audi and now no problem.
Old 05-09-2017, 05:39 PM
Gavo110's Avatar
That was a result I had same sort of issue in my 2000 a3 number 3 wasn't getting power even after bridging it to a live still ran like crap turned out to be ignition module on air box or ignition amplifier depends what car parts shop you go
googlegot
06-10-2012 06:25 PM
MJPassarelli
04-01-2010 04:04 PM
tketke
11-04-2008 12:01 PM
limptimtim
03-16-2007 11:21 PM
nitro_rider2001
02-27-2007 07:39 PM
Quick Reply: Still misfiring
