Fault Code help 2010 A3 TDI Bluetooth/Voice Recog/telephone Transceiver
Old 09-27-2013, 03:27 PM
jcinlaca's Avatar
Default Fault Code help 2010 A3 TDI Bluetooth/Voice Recog/telephone Transceiver
This is a 2010 A3 TDI that had several inches of fresh water on the floor, probably about up to the bottom of the seat
Where is the Bluetooth Module? Wanted to check for water damage. I've heard under the passenger seat, No... I asked an independent Audi shop he said, (with certainty) under the carpet, under the passenger seat. No, not there. Did force me to lift up carpet, find more dampness. Dehumidifier running in the car now. So, that's good.
I assume it's installed since it's a Premium Plus Model and under "Premium Plus" on the original window sticker", it states: "Bluetooth Hands-free phone interface"..... or does that mean it's just an interface ready for the Bluetooth Module to be installed??
When hitting the "TEL" button I get "Telephone not available" the the little phone icons are grayed out.
Are there any other item near the floor that the wetness might be causing my faults?
Here are the faults,
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0150
Revision: 000739 Serial number: 8P0820043BN
Shop #: WSC 00000 000 00000
VCID: 79F91F29301CD3D6D3D-802C
1 Fault Found:
01301 - Control Module for Voice Recognition (J507)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 43119 km
Time Indication: 0
Date: 2013.06.16
Time: 19:17:10
Freeze Frame:
ON
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7K0574708
Coding: 0000100
Shop #: WSC 06314 000 00000
VCID: 3663D4154182FCAE7EF-8063
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 4
Mileage: 43144 km
Time Indication: 0
Date: 2013.09.19
Time: 22:44:53
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 4683A4D531626C2EEEF-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
2 Faults Found:
01303 - Telephone Transceiver (R36)
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 P HW: 8P0 920 982 P
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2244J005002272
Coding: 0016288
Shop #: WSC 02136 444 125869
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 43144 km
Time Indication: 0
Date: 2013.09.19
Time: 22:46:38
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K1051903B9
Coding: ED817F07400712002102
VCID: 69D94F6940BC635623D-803C
2 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 43144 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 4
Mileage: 43144 km
Time Indication: 0
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 D HW: 8P0 035 193 D
Component: RNS-E PU US H04 0150
Revision: 0000006S Serial number: AUZBZ7K7000377
Coding: 0209645
VCID: 3169E709A8ECDB962BD-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 43144 km
Time Indication: 0
Date: 2013.09.19
Time: 22:49:15
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209645
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 4
Mileage: 43144 km
Time Indication: 0
Date: 2013.09.19
Time: 22:49:15
Address 77: Telephone
Cannot be reached
vfr800
B8 Models
03-24-2011 11:30 PM
parky
B7 Models
12-13-2010 01:12 PM
yanco
04-21-2008 10:47 PM
lcavada
03-25-2006 11:14 PM
Quick Reply: Fault Code help 2010 A3 TDI Bluetooth/Voice Recog/telephone Transceiver
