Transmission Input/Output Speed Sensor Fault on Audi A4 (2004)
Old 09-01-2009, 09:42 AM
rossboard's Avatar
Default Transmission Input/Output Speed Sensor Fault on Audi A4 (2004)
Hi All,
Just bought an 04 Audi A4 S-Line 1.9 tiptronic 140, the PRNDS is flashing on the dash, so took it to an Audi specialist garage today, they said that the Transmission input and output sensors were bringing up fault codes:
"18201 - Transmission Output Speed Sensor 2 (G196): No Signal"
"17101 - Transmission Input Speed Sensor (G182) No Signal / Implausable Signal"
They were planning on ordering new sensors, so on the drive home I took the car through the car wash, voila! the PRNDS stopped flashing and car was again fine!
The car hasnt been playing whilst driving and drives as it should, although later this afternoon on a local trip the light began flashing again and PRNDS is once again doing the same, although the car still drives fine.
Is it possible that the car wash cleaned those sensors temporarily? If so, where are the sensors located to give them a thorough looking at?
Thanks very much!
Ross
Old 03-04-2011, 05:55 PM
tommm's Avatar
Default problem whit 18201 and 17090
hola I have the same problem can you help me plese.
Thanks very much!
tommm
Old 07-07-2011, 10:31 PM
StanleyBenton's Avatar
Default Solution???
Hi guys!
I'm now experiencing that same problem in my sensor... just want to ask if you were able to solve this problem? or do i need a new transmission speed sensor?
Old 06-02-2021, 09:32 AM
skhasibs's Avatar
Default Sikhangezile Patience Malandu
Thanks very much!
tommm
My car also has the same problem. But its the transmission range sensor and the transmission output sensor. Have u solved yours
andrew456
07-23-2013 11:49 AM
ZeroAudi
04-27-2011 04:53 PM
slo1
04-18-2011 02:11 AM
nicalldat
02-09-2009 11:56 AM
bnyaudi
03-20-2007 02:14 AM
Quick Reply: Transmission Input/Output Speed Sensor Fault on Audi A4 (2004)
