Garrett GT2871r *BRAND NEW*
Trying to sell my brand new Garrett GT2871r, decided to go a little bigger with my engine build.
This is Brand new as stated, never even been mounted to any manifolds.
The Dual Ball Bearing GT2871R turbo assembly with T25 style turbine inlet comes with internal wastegate pre-assembled when purchased with T25 style housing. Optional "T3/T4 drop-in" style turbine housing available for an easy retrofit into older T3 based applications where T3 turbine inlet flange is required and either internal or external wastegate are used (internal wastegate assembly is not included when ordering T3/T4 drop-in configuration).
This turbo is great for small displacement engines up to 2.2L and has the ultimate spool up time compared to other units. This turbo has a flow capacity of about 400HP. The external packaging of this turbo is identical to that of the GT28RS and can be a nice stealthy upgrade to step up to 400HP of flow without much re-arrangement.
Turbine
-Wheel: 53.85mm w/ 76 trim
-Housing: .64 ar
Compressor
-Wheel: 71mm w/ 56 trim
-Housing: .60 ar
Please call me with any further questions 303-250-1777
Turbine
-Housing: .64 ar
Compressor
-Housing: .60 ar
Looking for $1000. costs about $1400 new. I will include the intake manifolds or $1700, as seen here;
http://www.uspmotorsports.com/GT2871R-Turbo-Manifold-2.0TFSI-TSI.html?gdftrk=gdfV210471_a_7c4200_a_7c11544_a_7c ATP_d_VVW_d_256&gclid=COLJ0bf3u8MCFQ6NaQodRQIA8A
njtrackstar
14
04-01-2009 11:49 AM
tomsnatchez
03-25-2007 03:47 PM
