2008 audi a5..oil pump failure
Old 09-22-2016, 12:28 PM
haniff31's Avatar
Unhappy 2008 audi a5..oil pump failure
Hey guys..im need some help for my problem..last month my car engine was jammed due to oil pump failure..then it cause the intake camshaft bend and the balance shaft broke..after replacing both parts the engine cant idle smoothly at cold start..it can idle smoothly after u constantly rev at 2500 rpm for 5 minutes..but if u rev the engine again it will vibrate and after few seconds it can idle smoothly..can anyone tell me exactly what happen to the engine??
Its already 3 months i left the car like that..or do i have to buy a new engine for better solution?
Old 09-22-2016, 01:20 PM
dave944's Avatar
It kind of sounds like the balance shaft could be not timed correctly. A balance shaft out of time will cause or amplify the very vibrations is it designed to cancel out. Primarily at idle speeds.
Old 09-22-2016, 10:03 PM
haniff31's Avatar
even if i have the correct timing setting?..so how i gonna solve the problem?
Old 09-22-2016, 11:07 PM
dave944's Avatar
If you are sure it is timed correctly it might be the coolant temperature sensor. Get the OBD error codes from the ECU before going any further.
Old 09-23-2016, 11:50 AM
haniff31's Avatar
Theres only one error code appeared..crankshaft position-camshaft position correlation bank 1 sensor A..is this related with the incorrect timing setting or any other problems?
I already set the timing 3 times and its 100% correct but this error code still appears. I also changed the camshaft sensor and the crankshaft sensor but it doesn't work at all.
Old 09-24-2016, 04:03 PM
dave944's Avatar
Without being there to put another set of eyeballs on it, I'm out of suggestions.... Hope you get it sorted though. It's probably something simple..
rcollins2867
B8 Models
04-26-2016 08:32 AM
demicami
Audi Q7
09-11-2013 02:23 PM
aimlesspoo
07-11-2013 10:03 PM
doylep
B7 Models
04-20-2013 01:18 AM
0fframp
03-09-2004 02:13 PM
Quick Reply: 2008 audi a5..oil pump failure
