AudiForums.com
Go Back   AudiForums.com > General > General Tech
Sign in using an external account
Register Forgot Password?
Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Welcome to Audi Forums!
Welcome to Audi Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Reply
LinkBack Thread Tools Search this Thread
Old 04-22-2011, 06:35 PM
Default Audi 80 (5000 KH motor) cutting, low power
I picked up a 1990 Audi 80 Quattro rally car. I'm sort of brand new to all things Audi, but I figured why not take the plunge and jump in head first, which is kind of crazy, which sounds about right for me. Anyway, the car is a bit of a Frankenstein- it has a KH motor in it from an 85 turbo. Ur CIS. Clutch is from an Audi 200 20v. And the the transmission and difs are 4000 quattro.
Car runs fine, idles fine, revs throughout the range smoothly. In gear, the car will run OK for about 1-2 mins. Then, when under load in gear, it first hesitates, stutters while accelerating. Then the problem gets worse fairly quickly to the point where when accelerating while in gear it bucks wildly, engine cuts, and I have to clutch in to stop it. You can almost minimize the problem if you barely give it throttle, but not by much it seems. Then power loss gets so bad, it won't even make it up the driveway.
I've scoured everything I could think of for vacuum leaks. I haven't done a PSI test on the injectors, but did a volume test, which was fine. So, onto sensors, unless someone can suggest some really elusive leaks to check for.
I have the MAC 11B ECU which has been modded by Intended Acceleration.
Here's what I know and have tested for on that front:
Pins 23 to 24 (intake sensor to ground) are supposed to be 13-33 ohms at room temperature. Mine measures 470 ohms. It was 45 degrees outside. Normal?
Pin 20 (idle switch) to ground measures 35 M ohms!, then climbs to an OL state. This is confusing.. Closed it's supposed to be 0, opened it's supposed to be infinite. I guess you could say it's shot?
Is there any way to check the Hall sensor? Any way to check the knock sensor?
Are there any other sensors I should be checking?
Reply
Tags
5000, 80, audi, audicomkh, date, despre, engie, engine, kh, low, motor, power, rain, studers, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Advertising Information -Contact Us - AudiForums.com - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
