Audi A4 Headlight replacement - AudiForums.com
Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Reply
Thread Tools Search this Thread
Old 04-28-2009, 04:21 PM
Question Audi A4 Headlight replacement
Hi. I'm sure this has been posted here with this question, but I am trying to figure out how on earth to change the headlight bulbs in a 2004 A4. I took it to the local auto parts store and they wouldn't even touch ti Any help would be much appreciated.
Thanks
Old 04-28-2009, 07:00 PM
You'll need a T-30 bit. There are either 3 or 4 screws to remove.
Old 04-28-2009, 11:22 PM
You'll need to remove and replace the whole headlight unit. You need to use the T-30 size Torx wrench. There are 4 screws that hold in the headlight, remove the two that are on the top area of the headlight and just loosen the two that are on the lower section, as they can by easily lost/dropped in the engine compartment. Remove the wiring harnesses and carefully pull out the headlight. (make sure to disconnect the battery before removing the headlight) Then just reverse the process with the new headlights!
Old 04-29-2009, 07:37 PM
If you have the V6 engine you will need to remove the air scoop to gain access to some of the screws.
Old 04-29-2009, 09:25 PM
Quote:
you DONT need to to replace the entire housing for a burnt out bulb
you DONT have to disconnect the battery
the rest is true.
Old 04-30-2009, 12:05 PM
the rest is true.
Disconnecting the battery is just a precaution, nothing wrong with that. And yes, it is true that you do not need to replace the entire housing when changing out a burnt bulb...BUT you still need to remove the housing to change out that bulb.
Old 05-04-2009, 08:13 AM
Question need help
i was able to replace the passenger side by removing the air filter assembly, but the driver's side was a real pain, not much room to work. i got it replaced, but im thinking removing the driver's side headlight might of been way easier. Does anyone have pictures or better details of where the lower screws are?
Old 05-07-2009, 02:33 PM
Quote:
Try this link : http://www.lustload.com/?p=147 is has detailed instructions and pictures.
Reply
Thread Thread Starter Forum Replies Last Post
2006 Audi A8 Headlight Replacement clewis37 Audi A8 0 04-14-2014 12:31 AM
Xenon Headlight Warning after Headlight Replacement oldmots Audi A6 2 04-24-2012 06:53 PM
Audi a4 1997 headlight replacement Vishone B5 Models 26 06-09-2010 09:11 AM
2004 Audi A4 1.8T Headlight Bulb Replacement gerardof71 Audi A4 1 01-10-2009 09:21 PM
Audi A6 low beam headlight replacement drwoods Audi A6 3 07-09-2007 10:10 AM
Tags
2001, a4, a5, audi, b8, bulb, change, changing, diy, headlight, headlights, replace, replacement, replacing, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
