07-16-2008, 05:23 PM
Bucking/Jerking on hard acceleration?
I have no check engine light on and no codes coming up. The mechanic replaced the ignition control module. It is still happening. Can it be the coil packs or random misfire without an error code? Any othe ideas? 1997 a4 1.8t
__________________
'97 1.8tqm... Pearl Ext./Black Sport Cloth Int...GIAC flashed...Forge 007...H&R Coilovers...Auto Meter Boost Gauge...K&N Filter Charger...AM Alloys...Tinted
07-16-2008, 07:56 PM
RE: Bucking/Jerking on hard acceleration?
no... if it was misfiring it has to throw a code... its afederal standard and required by law.
has your battery gone dead since this has been happening...?
__________________
Audi Technician
07-16-2008, 08:04 PM
No dead battery.. I just went out and looked around... The tubes connected to the air filter housing are sputtering.. drivers side fan on...passengerside fan is off. My temp gauge never moved above quarter way but now gauge is at half except when I went on highway
__________________
07-16-2008, 08:52 PM
hi guys my car is doing the same after just spending $2200 at a dealership....jerking under acceleration, but no codes thrown. Could this be bad plugs?, Just had one coil pack replaced and the others appear to be fine
07-16-2008, 08:56 PM
what do you mean by sputtering...?
__________________
Audi Technician
07-16-2008, 08:57 PM
cause a vacuum leak will give the same symptoms as misfire
__________________
Audi Technician
07-16-2008, 08:58 PM
My mechanic said not plugs or coils without engine light and error code. His online troubleshoot program led him to ignition control module (ecu). That didnt work. He said he also checked for vac leaks?
__________________
07-16-2008, 09:00 PM
>>sputtering meaning if u feel the tube coming in and the two after the split they are pulsating
__________________
07-16-2008, 09:03 PM
is there a whooshing or sucking sound...? 1.8T i notorious for vacuum leaks...
post your VIN number so i know exactly what generation of 18.T i'm dealing w/...
__________________
Audi Technician
07-16-2008, 09:05 PM
Sometimes a whale like noise
__________________
Tags
2008, acceleration, audi, boost, bucking, car, charger, hard, highway, jerking, leak, leake, misfire, sputtering, vacuum  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
