Looking for instructions, remove headlight assy, 99 A6 Quattro
We just became owners of a 1999 Audi A6 Quattro, 2.8
The right front headlight is foggy and looks terrible. We purchased a new headlight assembly and now cannot remove the old one. Any suggestions? We have removed the 2 top screws and the one long screw towards the motor side and still the unit cannot be removed.
RE: Looking for instructions, remove headlight assy, 99 A6 Quattro
theres probably some other screws in the compartment down below.
also, there may be some caps covering the screws
btw, the foggy headlamp, will probably return, they have a problem with that, and they dont care unless ther is OBVIOUS cracks, fyi
oh wow, alldata said you have to remove the front bumper! lol
Headlights, Removing and Installing
Removing
[*]Remove front bumper.[/ul]
[*]Remove both Torx bolts (T30) -1-.[*]Remove interior Torx bolt (T30) using 1/4"-Torx-bit insert and extension.[/ul]
NOTE: If necessary, use magnet to remove bolt.
[*]Disconnect multi-function harness connectors for headlights.[*]Turn headlights -2- toward center of vehicle and remove from chassis toward front.[/ul]
Installing
Installation is reverse of removal, noting the following:
[*]Adjust dimension -a- via plastic bolt at new headlight.[/ul]
NOTE: Determine dimension -a- at plastic bolt of old headlight, when being replaced.
[*]Engage headlight in area of center of vehicle in guide -2- via pin -1-.[*]Always align headlight according to contours of chassis (gap dimensions) and secure.[*]Adjust headlight after installing.[/ul]
Tightening torque
Component
Nm
Headlights to lock carrier
6[/b]
Removing
Installing
Tightening torque
Component
Nm
6[/b]
Brucifer
07-01-2013 04:02 PM
02AudiA63L_65
09-16-2010 05:34 PM
