Misfiring issue on Audi TT 2009
Old 07-31-2014, 12:12 AM
Reuben's Avatar
Default Misfiring issue on Audi TT 2009
1. 2009
2. Audi TT 2.0t Quattro
3. Auto
4. 39,000
Hi guys, picked up a 2009 TT around 6 weeks ago. The car passed smog and registered the title and the last 6 weeks have been awesome with the car with not a single hint of a fault. The car is driven daily around 40 miles to work and back. Been brilliant driving it.
It does have an APR stage 1 tune, but the tuning is very nice, with a little lag, before it takes off.
Monday going to work, the car was sitting idle at the weekend as I have a family car for the weekend, started up ok and drove around 3 miles at no more than 35MPH to get to the highway on ramp. Upon getting the onramp I did floor the accelerator, and rather than the car taking off like it normally does the revs just died and the car started to misfire. No sign at all anything was going to go wrong, until I floored the accelerator.
Now it misfires and shakes at idle. Small smell of fuel, perhaps not being burned off... No leaks from the engine and apart from the misfire.
The EPC and engine management lights are both on.
1. Changed the sparkplugs
2. I also changed the ignition coils
3. I disconnected the MAF and made no difference, the car is misfiring with the MAF connected or not
4. I also did a reboot
I called the previous owner and he said he replaced the fuel injectors at 30,000miles, so the new injectors have less than 10,000 miles on them.
Running the Vag-Com or Ross-Tech. Then showing bunch of error codes, hence I tried the spark plugs and ignition coils. But I am getting the same error codes everytime.... Any ideas what could be wrong ?
Thursday,31,July,2014,10:59:01:38826
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
**I deleted the VIN part below**
VIN: TRUVF38Jxxxxxxxxxx License Plate: BUY777-2
Mileage: 63120km-39220mi Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 0F 10 15 16 17 19 22 25 37 42 44 46 47 52 55
56 65 77
VIN: TRUVF38Jxxxxxxxxx Mileage: 63120km/39220miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System --Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: None
Part No SW: 8J0 907 115 M HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: AUX7Z0H9FNK111
Coding: 0113010A1C0F0160
Shop #: WSC 01236 785 00200
VCID: 36639CCA41D0D7AE71B-8063
13 Faults Found:
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 62242 km
Time Indication: 0
Date: 2014.06.25
Time: 08:33:21
Freeze Frame:
RPM: 1173 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 51.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.684 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 63118 km
Time Indication: 0
Date: 2014.07.28
Time: 07:02:58
Freeze Frame:
RPM: 2503 /min
Load: 62.7 %
Speed: 16.0 km/h
Temperature: 68.0°C
Temperature: 21.0°C
Voltage: 13.462 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 63118 km
Time Indication: 0
Date: 2014.07.28
Time: 07:02:58
Freeze Frame:
RPM: 2503 /min
Load: 62.7 %
Speed: 16.0 km/h
Temperature: 68.0°C
Temperature: 21.0°C
Voltage: 13.462 V
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 63118 km
Time Indication: 0
Date: 2014.07.28
Time: 07:03:00
Freeze Frame:
RPM: 3939 /min
Load: 70.2 %
Speed: 34.0 km/h
Temperature: 69.0°C
Temperature: 21.0°C
Voltage: 13.716 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 42.0°C
Temperature: 33.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.811 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 63124 km
Time Indication: 0
Date: 2014.07.30
Time: 18:46:39
Freeze Frame:
RPM: 774 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 46.0°C
Temperature: 34.0°C
Voltage: 13.208 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 63124 km
Time Indication: 0
Date: 2014.07.30
Time: 18:32:16
Freeze Frame:
RPM: 1087 /min
Load: 42.3 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 34.0°C
Voltage: 13.462 V
Readiness: 0000 0000
Wanttobuyanaudi
B8 Models
10
07-09-2016 11:14 PM
theunknownprince
B7 Models
23
02-23-2016 01:17 PM
zipster8
B8 Models
08-21-2015 09:25 AM
RobBolejszo
S4
06-11-2013 02:56 PM
Jester008
B8 Models
09-14-2012 09:15 AM
Quick Reply: Misfiring issue on Audi TT 2009
