New A6 recall
New A6 recall
There is a new recall for the older A6. It is to replace the throttle body again. It dose not apply to all of them, only the 2.8L in the "cold wether zones" All it dose is replace the old one with a updated throttle body with a internall engine coolent line. It is to make shure that the throttle flap dose not stick. From what i heard some one in some far off place almost had this problem. But since Audi is **** retentive, there is now a recall. Just to let you know.
RE: New A6 recall
Yes Slim the problem proly has come up a few times. Audi not THAT bad. Jestnomen, I am a tech for a dealer, and have done about 4 JB recalls on the 2.8 a6's. There is a hard pipe coolent line that runs under the throttle body, it has two nipples that you take the old hose off that used to run snug with the t/b to heat it, but now when you replace the t/b with the new one there are ports in the bottem of it that you connect them to. nothing big. takes about a 1 1/2 hour.
RE: New A6 recall
Ted and others, I was searching for recall notices here....found this one.. but I have problem with front suspension in my 2000 A6 Avant. As there any recall about this. I am a new member and just posted longer description of this problem in new member section- if you dont't mind please check quickly there..
Thanks Pete
Thanks Pete
