replacement of timing belt...
RE: replacement of timing belt...
That tutorial is not for your engine. Check out the 12 valve forum on Audiworld for instructions. Just post for there for instructions. I don't have the link to the diagram anymore.
http://forums.audiworld.com/12v
You'll probably also need a cam lock tool as well as the crank holding tool. It's pretty important to have them to keep the cams lined up with each other, otherwise you'll cause engine damage.
fritz
08-12-2007 02:55 PM
