Trouble code: PO431-Help! - AudiForums.com
Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Reply
LinkBack Thread Tools Search this Thread
Old 07-25-2006, 05:57 PM
Default Trouble code: PO431-Help!
Hi Everyone-
I have an Audi A4 3.0 Quattro, 2002. My engine light came on, so I took it to an auto body shop just to find out what the light meant. My trouble code says: Warm Up Catalyst Efficiency Below Threshold (Bank 2)
What does this mean and what should I do about it? Do I really need to do anything about it??
Old 07-25-2006, 06:44 PM
Default RE: Trouble code: PO431-Help!
Are you sure the code isn't P0432 ?
Old 07-30-2006, 03:57 PM
You probably need a catalytic converter. It should still be under warranty if you have less that like 75k miles.
Old 07-31-2006, 03:32 PM
Thanks, I will check into it. The guy who revealed the code to me said that to replace a catalytic converter, it's a big deal. Like, it opens a can of worms and can cause other problems. What do you think?
Old 07-31-2006, 03:34 PM
I was told P0432....but I suppose it could have been a mistake. What is PO431? What makes you think I have the wrong one?
Old 07-31-2006, 03:58 PM
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2).
P0432 main catalyst bank 2 (not heated type).
also could be the o2 sensor/wiring
Old 07-31-2006, 05:34 PM
Sorry about that..you got me a little confused. YES: it is PO431 as stated in the original subject line.
To all that have posted replys: thank you very much, however...
if it's the catalytic converter or the O2 sensor, how important are these things and typically how expensive??
I do not want to get hosed at the dealership. I find them to be a little...um...dangerous for someone that doesn't
know a lot about the inner workings of a car. I'm learning, but I'm not that confident I come out of there 1000K in debt...
Old 07-31-2006, 05:53 PM
so its the warm up cat type then (expensive) but a DIY job and simple as changing an exhaust using the proper safety stands before you go under there, look for a universal catalyst as they are half the price
Old 07-31-2006, 05:56 PM
you could also fit a test pipe to make sure its the cat,
im not suggesting you leave it in there cough because it will give you too much power cough
Old 08-04-2006, 05:44 AM
I
the catalyst have a 10 years warranty at audi dealership... dont worry!!!
Reply
Thread Thread Starter Forum Replies Last Post
Audi A4 code PO431 bernes1982 B6 Models 1 06-14-2012 01:03 PM
CEL Code PO431-DTC- Help Confirming Plse Audiman62 Audi A4 1 11-03-2011 01:20 PM
CEL Code- PO431-DTC on 2003 A4 Cab Audiman62 B6 Models 0 11-02-2011 11:21 PM
2002 Audi A4 3.0 Quattro scan code PO431 silver a vier B6 Models 1 09-17-2011 04:04 PM
Trouble Code MAF nikotoma23 B5 Models 2 08-30-2009 09:35 AM
Tags
2002, a4, a6, audi, bank2, cat, catalyst, catalytic, converter, efficiency, p0432, po431, quattro, threshold, warm, warming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
