Trouble with transmission P0706
Old 07-25-2016, 03:39 PM
ProlificScarcity's Avatar
Default Trouble with transmission P0706
Hi Everyone,
I have a B7 2006 Audi A4 (CVT transmission). I have had my PRNDS flashing for quite some time now. Due to transmission range sensor code being active (P0706) I understand that the TCM is bad and needs to be rebuilt/replaced. What I need help with is understanding if my actual transmission is damaged, and if it is worth fixing the sensor.
Symptoms:
-Between 1700 and 2000 RPM, the RPM needle pulses and the car jerks, regardless of the speed/gear.
-for the above reason, I try driving in triptronic mode and keep RPMs over 2000, with minimal issues but now it is showing some signs of the below issue in triptronic as well.
-more recently, the RPMs will go up gradually to 3k then 4k but the acceleration does not increase with the RPMs, which is unusual (mostly in Drive, and sometimes in triptronic mode now)
-Triptronic gear shifting is generally smooth except for when i switch between second and third gear, at that point the car jerks a bit
-also more recently the turbo no longer engages
-Sometimes the reverse does not engage
Also the following codes appeared:
P1624-MIL Request Signal Active (Check TCM for errors tool) - Intermittent
P2293-Fule Pressure Regulator Valve (N276) - Mechanical Malfunction - MIL ON
P0087-Fuel Rail/System Pressure - Too low - intermittent
P310B-Low Pressure Fuel regulation - Fuel pressure outside specification - intermittent
P1602-Power Supply Terminal 30 - Voltage too low - intermittent
I should add that my head cover gasket is leaking. I have had to replace ignition coils and spark plugs in the past. I will fix the problem, once I figure out the transmission issue.
Any help will be appreciated.
Old 11-03-2016, 10:31 AM
Madelineff's Avatar
Originally Posted by ProlificScarcity
Hi Everyone,
Symptoms:
If you contact Audi and tell them about the issue and let them know that after looking up the issue online you saw that it was a very common issue they will notate it and if they hear enough people calling it in they will make a recall and fix the issue.
Old 11-09-2016, 02:35 PM
I think Audi already knows about this issue and they will cover it for a maximum of 100K as far as I have read on the forums.
Old 04-10-2019, 03:32 PM
Jared Adkins's Avatar
Hi Everyone,
Symptoms:
Did you ever replace the tcm and did it work ? I’m having the exact same issue with my 06 2.0T and the new one cost just under 2 grand so I want to make sure what my problem is before I do anything it sucks to because i got the car in Alabama at my moms and now I have to get back to work so I guess I’m just going to drive the 500 miles like it is and hope for the best , just have to keep it above 2 grand or at 1500 or below and it runs fine but for how long is the question . Let me know how it went for you so I can decide if I should put the money in it or just cut my losses now.
Boose
S3
04-04-2018 05:34 PM
bsokoll
09-15-2016 03:53 PM
bsokoll
06-02-2015 06:14 PM
Hazim Mandavia
B7 Models
07-06-2014 02:11 PM
audidriver4life
05-07-2005 01:34 AM
Quick Reply: Trouble with transmission P0706
