Turn signals don't work.
Old 06-28-2008, 01:27 PM
SingBlueSilver's Avatar
Default Turn signals don't work.
Hi all,
I'm having a turn signal issue. They won't even flash. Checked the fuse, it's not that. The hazards work. Any suggestions? Anyone have this issue before and/or the know-how to remedy it?
I'm so desperate I'm almost considering offering a freakin' reward. But, for now... Thank you graciously for your help.
Old 07-01-2008, 08:01 AM
Jc61990's Avatar
Default RE: Turn signals don't work.
sounds like a relay
Old 07-01-2008, 11:32 AM
Ok, simple enough. How do I fix it? Or, where can I find information regarding that?
Old 07-01-2008, 05:57 PM
Jc61990's Avatar
try this http://wiki.answers.com/Q/Where_is_t...02_Audi_A6_27t
Old 07-02-2008, 05:40 AM
Ady_E's Avatar
Also, check this out: http://www.tyresmoke.net/forum/audi-...ndicators.html
Should answer all your questions.
Old 07-09-2008, 08:25 PM
geoff's Avatar
you've got a bad hazard switch bud, the hazards will still work but the relay for the turn sigs lives in there as well and that goes bad. One out of every 100 times i've seen a turn signal stalk go bad, but considering how cheap thehazard switch is it's worth taking a shot. pull the trim off around the hazard switch, esp button,etc and pull the switch out. all you need is a flat head screwdriver
topdog1
04-25-2011 12:15 PM
seven77777
01-19-2011 08:43 PM
insanoman85
11-02-2010 12:50 PM
WintonA4
10-02-2010 04:26 PM
6cylbiturbo
12-02-2005 09:14 PM
Quick Reply: Turn signals don't work.
